abs problem
Old Sep 11, 2005 | 10:32 AM
4thgradedropout's Avatar
abs problem
ok so the little black abs moter box on the left front side of my engine keeps running after i turn my car off...and my cruse controle light comes on when this happens even though ive never used my cruse controle..any ideas?
Old Sep 11, 2005 | 10:46 AM
Wiking's Avatar
Originally Posted by 4thgradedropout
ok so the little black abs moter box on the left...
...last sound: *bosch*
The ABS relay is most probably stuck. Hit him into head, replace... or take ABS fuses off [right side; http://www.cardomain.com/ride/748507/5]
for more clic on http://www.cardomain.com/ride/748507/18
Old Sep 11, 2005 | 05:10 PM
internetautomar's Avatar
mod or sell?
2 options:
1. fix and repair unit/relays as well as g-d only knows what else ($-$$$$)
2. Disable ABS, by pulling fuses and connectors ($0)
Old Sep 11, 2005 | 05:30 PM
Greeny's Avatar
¯\(°_o)/¯
I'd go with #2.......Early 90's abs systems were not that great even when they worked...:
Old Sep 11, 2005 | 05:41 PM
CyMax's Avatar
I can verify our ABS systems freak out. Mine liked to totally lock the wheels when I hit the brakes and turned at the same time. NOT FUN!!! Fuses pulled.
Old Sep 12, 2005 | 01:38 AM
Wiking's Avatar
My guess is shorting front wheel sensor wiring... turning causes wire to twist.
As described http://www.cardomain.com/ride/748507/18 , typical ABS electrical problems are wiring/ grounding /dirt related.
ABS computer also has the self test which may point to the problem source.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
wingnut2006
Sep 19, 2015 06:13 AM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
