trunk release
Old Sep 13, 2005 | 07:37 PM
vansskaterfreek's Avatar
trunk release
the trunk release is messed up on my car... i know about the way you must poush it to work correctly, i think my cable is stretched.....how hard is it to put the button trunk popper in my car.......alot of work?????it comes with 92-94 maximas right?
Old Sep 13, 2005 | 08:07 PM
goon9's Avatar
Good question. I'm about the put a poper on my trunk. But I was going to run an aftermarket one right on the lid. Shouldn't be too hard.
Old Sep 13, 2005 | 11:02 PM
maxmaxima91's Avatar
you might have been talking about this but.... have you checked in your trunk there is a lever type thing right under were the trunk lid latches. if it is in the wrong possition the realeas lever will not work, only the key. i think i slides up and down.
Old Sep 14, 2005 | 04:00 AM
Wiking's Avatar
Originally Posted by maxmaxima91
... i think i slides up and down.
Alas, its doing this slide-down all ways on its own... I had to prop it up with a piece of foam, now it stays always up.
The reason (?) was that the veery reliable Nissan mechs should not be able to peek & select your items from trunk (=steal more), while being presumably (lol) serviced. Originally in u car there was one red service key for them, that key does not fit the trunk lock.
Old Sep 14, 2005 | 07:13 PM
well i dont have that key, yes the little lever thingy in the trunk is up, it just doesnt spring back after i pull the lever from in the car. is the auto one hard to do???
Old Sep 15, 2005 | 01:34 AM
Wiking's Avatar
0. First to be lost... I hope its there someWhere.
1. Maybe the wire jacket is loose? Take panel oof &verify.
2. Relatively easy = point 1. x 100 (somebody here surely ? has done it...)
Old Sep 16, 2005 | 01:26 PM
Phoenix's Avatar
Lives in a Maxima
Ok, I have a similar problem...
I have a 92 SE with the electronic release... i press it and the trunk goes *thunk*. I can turn the key in the trunk and nothing happens.
Last week, both/either methods of opening the trunk worked. I have now removed everything from behind the arm rest in the back seat, so I can fit one arm and my head through, hoping to reach the Cancel Switch, in case it's flipped.
No luck. I can't reach that far, especially over a golf bag. Any tips?
________________________
redSeraph
92 Maxima SE 5-sp
225,656mi and counting!
Old Sep 16, 2005 | 01:36 PM
Greeny's Avatar
¯\(°_o)/¯
redSeraph
92 Maxima SE 5-sp
Take the rear seats out....Start with the bottom cushion,get your fingers under the cushion in the front when meets the carpet and start yanking....Then the part that you lean against has a screw on each edge,down low....Then in the middle of the seat where the armrest is....
Old Sep 18, 2005 | 01:19 PM
Phoenix's Avatar
Lives in a Maxima
Took the rear seat out, about 2 hours of poking and prying... seems like the lock was just jammed. once I got it opened once, it's been working fine.
To keep this from happening again, I thought about giving the locking mech a proper lube. Graphite? Or does anyone have a better suggestion?
Old Sep 18, 2005 | 01:26 PM
Greeny's Avatar
¯\(°_o)/¯
Graphite or Whit lithium grease works fine...
REDinLV
Aug 15, 2024 12:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
05RLS2
Sep 27, 2015 09:24 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
