My brights are gone. Headlight switch part #?
Old 09-14-2005 | 10:54 PM
puna2k's Avatar
My headlights have lost the brights, At first it was just the right side bright, then the left went-but sometimes works for a minute. I changed the 9004 harness's before to heavy duty ones when I put eurolights in. I'm thinking it's the switch in the steering collum. Anyone else go through this problem?
Anyone know the part number off hand?-so I can search for it online without getting a web site run around.
Old 09-15-2005 | 03:56 AM
Wiking's Avatar
Originally Posted by puna2k
... I put eurolights in. ...
The sw is bad quality, eventually fails always. Overload it, and soon its burned. Clean it and install relays, the sw might survive long time with the minuscle relay load. I installed relays before the burnup, like this. Voltage to lamps was boosted 30%... brightness explosion.
clic on http://www.cardomain.com/ride/748507/11
Old 09-15-2005 | 04:01 AM
Greeny's Avatar
¯\(°_o)/¯
The hi beam switch on these cars is prone to fail......Mine done the same thing.....The switch is about $60 buck at idiotzone.
Old 09-15-2005 | 04:20 AM
Greeny's Avatar
¯\(°_o)/¯
part #'s......
w/Air Bag, : Headlamp Dimmer Switch.# 25540-40U60
w/o Air Bag, : Headlamp Dimmer Switch.# 25540-40U61
Old 09-16-2005 | 04:01 PM
ghostmax's Avatar
you can take apart the switch itself and clean the contacts. worked for me. just watch out when you take it apart...
Old 09-18-2005 | 01:00 PM
Dillbag's Avatar
Suprise butsechs!!!
Good idea with using the relays to reduce elec. load on the switch. See, now this is stuff worth talking about.
vingodine
45
05-21-2016 12:46 PM
Shock_and_Awe
08-23-2015 01:02 PM
KristyKarina
08-23-2015 09:53 AM
Viralkill
08-16-2015 05:09 PM
Quick Reply: My brights are gone. Headlight switch part #?
