Spedometer issue
Old Sep 15, 2005 | 12:03 PM
4dscPat's Avatar
Spedometer issue
I replaced the speed sensor and still no go. Before I replace the gauges, I want to test the signal going into the gauges to see if it's something inbetween the sensor and the gauges. Does anybody know what terminals I should test on the plugs that go into the gauges? And what kind of voltage I should be seeing?
Old Sep 15, 2005 | 12:51 PM
Tarzan's Avatar
I wish I new! My speedo is fine and the odometer is dead (almost 99% but it's a long story). You'd need an oscylloscope because it's not just DC.
Old Sep 15, 2005 | 07:17 PM
Greeny's Avatar
¯\(°_o)/¯
The instrument cluster is most likely your problem....check the classifieds section for a used one....
Old Sep 15, 2005 | 07:24 PM
mtnbikeair's Avatar
I had this problem... if you take your guage cluster out and put connection stuff under all of the screws on the back and then tighten all of the screws then it just might start working. I had like one slightly loose screw and it made the speedo stop working.
Old Sep 15, 2005 | 08:31 PM
subs1000w's Avatar
you could probobly read the output with a AC voltmeter not sure what wires
Old Sep 16, 2005 | 01:25 AM
Wiking's Avatar
Originally Posted by 4dscPat
...what kind of voltage I should be seeing?
Check for more at http://www.cardomain.com/ride/748507/9
...details? ...all is there: clic Favorite Links top left
Old Sep 16, 2005 | 06:01 AM
Tarzan's Avatar
Been there done that. Cluster swap does not work. I am not stupid, usually when I am saying it is a weird problem - it indeed is weird
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
