lots of vg manifold stud replacement pics/ 56k, get some cereal
Old Sep 18, 2005 | 10:39 PM
mattcomet82's Avatar
so i have finally uploaded my manifold stud replacement pics and decided i had better share. i hadn't planned on writing up a whole 'how to' but if you guys have any q's i'm more than happy to answer. enjoy
Old Sep 18, 2005 | 10:40 PM
Old Sep 18, 2005 | 10:41 PM
Old Sep 18, 2005 | 10:43 PM
Old Sep 18, 2005 | 10:44 PM
Old Sep 19, 2005 | 12:26 AM
Wiking's Avatar
Eh.
My q: Is tHere smbdy who has not yet seen an oily engine?
Hint: build u site, post a link.
Old Sep 19, 2005 | 04:28 AM
disgruntled's Avatar
just one question: What air tank capacity do you have to operate that 90 degrees drill? All I have is a 25 gallon tank, and I need to fix the studs soon, one of my exhaust nut actually broke off and went flying while I was on the highway.
Old Sep 19, 2005 | 05:56 AM
MrGone's Avatar
I went and grabbed a bowl of cereal even though I have broadband
I swear it looks dirtier in the pics than it did when you were over. Head/header looked brand new
Old Sep 19, 2005 | 06:08 AM
i may have done a little de-turding....
wiking you were asking me for these pics last week!?!? the pics you get are only so good with filthy hands on an ezxpensive digital cam...
Old Sep 19, 2005 | 06:11 AM
i believe its around 30-40 gallons, about average. there's not much drilling you need to do, so even a smaller tank should work. you only need to drill about 3/8" on each busted stud.
Old Sep 19, 2005 | 06:16 AM
Greeny's Avatar
¯\(°_o)/¯
I wonder when mine are going to break.......285,000 and none yet.
Old Sep 19, 2005 | 06:41 AM
Dillbag's Avatar
Suprise butsechs!!!
MyGreenMax94, have they been changed before you got the car?
Old Sep 19, 2005 | 06:43 AM
Dillbag's Avatar
Suprise butsechs!!!
mattcomet82, two things: Is that a Carquest oil filter I saw on your engine? And also, it looks like it's time to tighten up those valve cover screws.
Old Sep 19, 2005 | 06:56 AM
Greeny's Avatar
¯\(°_o)/¯
Naw....The previous owner kept meticulous records of all service done to the car...Even the oil changes were documented and a receipt stuffed into the owners manual booklet.....
Wiking's Avatar
Originally Posted by mattcomet82
...wiking you were asking me for these pics last week!?!? ...
Did I? Hmm. My apologies, should I ? apply for bigger tinhat: "...went and grabbed a bowl of CE-real even though I have broadband..."
Pic quality ok, qty overflowin...
Old Sep 19, 2005 | 06:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
bastid you got a lift
Old Sep 19, 2005 | 07:16 AM
maxitech's Avatar
Having a lift would be key, at least my buddy has one! Nice Blehmco Grounding Kit.
Old Sep 19, 2005 | 01:14 PM
goon9's Avatar
THANK YOU! Finally some GOOD pics.
Did you have to remove the radiator?
Old Sep 19, 2005 | 03:25 PM
tripleGmax's Avatar
isnt it great to not hear the thing go putt putt putttttttt?
hows the muffler?
Old Sep 19, 2005 | 06:22 PM
Alex_V
sweet. But why does everything on your car look new?? >< I want mine to look that good under hood....
~Alex
Old Sep 19, 2005 | 06:24 PM
Greeny's Avatar
¯\(°_o)/¯
~Alex
It was most likely taken care of ....Or steamed cleaned....
Old Sep 19, 2005 | 06:30 PM
vansskaterfreek's Avatar
i grabbed a strawberry pop tart, and even toasted it, LOL
Old Sep 19, 2005 | 06:56 PM
quite a few q's, one at a time.
yes, it is a carquest filter. one of the two knowledgeable places around here, plus my buddy has an account.the valve cover gaskets are probably original, but i'm not putting any more work into this motor. i have a spare vg i'm about to pull and rebuild. i wanted to get a few more hours under my belt with a mxima before i did a major rebuild.
yes, all things are possible with the strength of our lord the lift. i never would have tried this had i not had one. notice the tranny jack in the corner?
the radiator stayed there the whole time. all i had to remove on the front side was the compressor and dipstick tube mount. i did have a 90deg drill and lift, it may be necessary to remove without these luxuries. i did replace the fan shroud while i was there.
it's so nice to have fully contained exhaust. i still have yet to chop the old and weld on the new magnaflow, that'll be next.
it hasn't been steam cleaned, i just try to keep it looking good. having all those pieces off gives you an opportubity to reach some remote filthy places as well. plus i still have all my under motor shields.
Old Sep 19, 2005 | 07:43 PM
maximaboi's Avatar
is it just the VG that has this issue or is it both the VG and the VE?
Old Sep 19, 2005 | 07:55 PM
Greeny's Avatar
¯\(°_o)/¯
They both have the stud issue.......Except mine
Old Sep 19, 2005 | 08:03 PM
Dillbag's Avatar
Suprise butsechs!!!
I didn't say, replace the v/c gaskets, just tighten the screws, silly. It sometimes helps the leaks slow down, or stop untill the screws loosen again.
Old Sep 19, 2005 | 08:07 PM
Greeny's Avatar
¯\(°_o)/¯
Huh ?????
Old Sep 20, 2005 | 06:27 PM
yeah, i have tightened those pieces. anybody else gonna tackle this job soon? good luck if you're working on the rear bank.
Old Sep 20, 2005 | 09:55 PM
Hectic's Avatar
i hope not, input shaft bearing is enough for now . looks good man, congrats.
Old Sep 21, 2005 | 06:19 PM
thanks. are you replacing the bearing yourself? i have two 5spd transaxles with bad i.s. bearings, info on replacement/ refurb would be much appreciated. i'd like to rebuild my trans before i start my vg rebuild.
Old Sep 22, 2005 | 10:15 PM
VEvolution's Avatar
I miss my VE
Yeah, me. Gonna do it in the AutoZone parking lot with a ratchet set. Can't wait.
Anyway, Nice job. What are the signs of needing to replace exhaust studs?
Old Sep 22, 2005 | 10:55 PM
505max94se's Avatar
MrGone, is mattcomet82 the guy that I met when I came to house?
Old Sep 23, 2005 | 05:25 PM
the one and only...
Old Sep 23, 2005 | 05:34 PM
only a ratchet set? you may need quite the cheering section to get through this one. if you can't visibly tell if your studs are busted already, go under the hood and pump the throttle a few times while the motor is still warming up. you should be able to notice if you have an exhaust leak. if you have a leak, most likely at least a few studs will be busted during disassembly.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
FlaMark
Aug 21, 2015 11:06 AM
MaxStock
Aug 12, 2015 08:33 AM
