Changing CV joint. HELP
Old Oct 1, 2005 | 01:02 PM
avusblue92se's Avatar
Ok, so I am removing the bolt which holds on the hub assembly(36mm), and I am having a heck of a time. Is this a standard bolt or is it reversed thread? I have used a breaker bar for a normal directional bolt and can't seem to get it to budge. I have my wife stepping on the breaks so the axle doesn't move. Please advise.
Old Oct 1, 2005 | 01:08 PM
Greeny's Avatar
¯\(°_o)/¯
You should be going counter clock wise to loosen the nut....Go find a strong piece of pipe to put over the end of the breaker bar to make it longer ....This will increase your torque on the nut.....And some pb plaster won't hurt ...
Old Oct 1, 2005 | 01:19 PM
Wiking's Avatar
... I have my wife stepping on the breaks...
- spray liberally CRC, let it seep in
- use pneumatic bolt opener
- use six feet steel tube extension, neighbors wife hammering on the nut while u dangle in air...
- propane torch/ electric welder to heat expand one side of the nut
- break the nut by grinding /cutting it, buy new
Old Oct 1, 2005 | 01:22 PM
twinkle's Avatar
why the neighbors wife, whats wrong with yours?
Old Oct 1, 2005 | 01:25 PM
I put a long pipe on the end of my breaker bar and am turning counter clock wise. I am turning the hubs. Car is in 1st gear. What is going wrong?
Old Oct 1, 2005 | 01:29 PM
u dangle in air...
next up I will try danling in the air
Old Oct 1, 2005 | 01:32 PM
Greeny's Avatar
¯\(°_o)/¯
Put the wheel/tire back on the car,and drop it down to the ground....then turn the nut......with the car in gear and the e brake on...
Old Oct 1, 2005 | 02:03 PM
Wife was not pressing on the brakes hard enough. Now any suggestions on how to separte the hub from the spindle? I have been hitting it with a peice of wood an a hammer and it doesn't seem to be budging. Thanks for all of the help.
Old Oct 1, 2005 | 02:07 PM
Red89maxima's Avatar
Put a screwdriver into the slots of the rotor, where the caliper sits. So that when you turn it the screwdriver pushes against the caliper and stops the hub from turning. Make sure it's a decent size screwdriver and make sure the screwdriver is pushed as far as possible into the middle of the rotor. Some calipers have a hole in the top of them where you can get to the rotor, I usually out it in there, so there's less movement.
Some might say this is Hillbilly, but it has always worked for me and never had any problems with it.
Old Oct 1, 2005 | 02:09 PM
Thanks. I got the nut off, the wife was not pressing on the brakes hard enough. Now I am trying to get the hub off of the spindle assembly. I am pounding on it with a hammer and a piece of wood to no avail. Any advise? Thanks.
Old Oct 1, 2005 | 02:13 PM
Alex_V
just take off the strut, the 2 17mm bolts/nuts and then the 14s through the shock tower, then let the spindle fall and wack out the axle. ive done 3 maxs and a mx3 in the last month, it always worked.
~Alex
Old Oct 1, 2005 | 02:15 PM
Hub off the spindal? Which bolts have you undone or what are you planning on doing?
Once you have your outer axle nut off you can just unbolt the three bolts holding the lower control arm to the knuckle and pull the whole knuckle, strut assy outa the way to slide the Axle out
Old Oct 1, 2005 | 02:17 PM
Don't take the whole Strut assembly out !! there's no need just unbolt it from the lower and leave the tower bolts in and pull the knuckle/Strut off to the side as you slide out the axle
Old Oct 1, 2005 | 02:24 PM
I am just following the chiltons directions. It states to "separate the halfshaft from teh steering knuckle by tapping it with a block of wood and a mallet". It shows a picture with the hub and brake sheild off of the strut assembly.
Old Oct 1, 2005 | 02:37 PM
Don't have to just follow my above directions
Which side are you doing?
But I will leave it on, and just take out the bolts from the control arm and slide the spindle to the side. Thanks for the advice.
Old Oct 1, 2005 | 03:02 PM
4dscPat's Avatar
When I did it, I left the car on the ground and had a friend step on the brakes, put PB blaster on the nut, and used a 3 foot cheater pipe. Came right off.
Old Oct 1, 2005 | 03:03 PM
Greeny's Avatar
¯\(°_o)/¯
Post #7 pat.....: j/K
Old Oct 1, 2005 | 04:03 PM
Now I am trying to separate the cv joint from the support bracket, and pull it from the tranny. I am going to spray on some wd40; do you think that will loosen it up? I can not get it to move at all. This has been a stressful fix so far.
Old Oct 1, 2005 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
Here are some pics to help you....separate at the point in the pics....
Old Oct 1, 2005 | 04:28 PM
It seems to be rusted together. I am going to spray it with wd40 and then try again. Thanks for all of your help.
Old Oct 1, 2005 | 05:50 PM
When I fisrt did mine they were really hard to seperate right there too, I just pryed it out with 2 Prybars, one on each side and pry back and forth alternating from side to side.
Also putting a prybar to one of the mounting ears and hitting it with a hammer to turn it should loosen it so that you can get them apart
Old Oct 1, 2005 | 07:41 PM
falseicon's Avatar
dropping a crow-bar down from the top (behind the back of the engine) and hammering the support bearing bracket (outside portion of the cv shaft) so it will spin was my only solution to breaking the rust.
Old Oct 2, 2005 | 03:03 PM
Thanks everyone for all of your help. It was finally finished this morning after topping off the tranny with some synthetic gear lube. It was definately a very "fun" project.
Old Oct 2, 2005 | 04:03 PM
Don't worry it'll be easier the second time around !!
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
