Trans Problem
Old Oct 17, 2005 | 04:19 PM
BobbyR1972's Avatar
Trans Problem (Please Help)
My car has troubles. 1993 SE w/AT . I'm driving along at a regular pace all of a sudden the engine races up and I feel no power increase it's like it went into neutral or something. I usually have the rocker switch in the middle position. Sometimes when this happens the P light starts flashing. My mechanic already told me that I have to replace an injector on my engine. I think this is a totally independant problem. Anybody know what it could be????
Old Oct 17, 2005 | 07:38 PM
maxitech's Avatar
It's not your injector!
Old Oct 17, 2005 | 08:08 PM
tripleGmax's Avatar
do you have fluid in the tranny?
Old Oct 17, 2005 | 08:48 PM
red-line-racer's Avatar
sounds like the prob is in the trans
Old Oct 18, 2005 | 12:32 AM
Wiking's Avatar
Originally Posted by BobbyR1972
...I think this is a totally independant problem. ...
I dont know what it is. I know what it could be. For Tranny Writeup Click on http://www.cardomain.com/ride/748507/15
ECU & TCU play together. Certain chain of effects input serie may cause ECU to command TCU safe mode: third gear, 2.2krpm limit, feels loss of life. Start by Repair of the injector.
Old Oct 18, 2005 | 03:42 PM
wawa92gxe's Avatar
check your shifter bushings. It could be worn and gone then your shifter happened to fall into neutral position. It happend to mine once and a new bushing worth of $2 fixed it.
Another posibility could be intake vacuum leak. check carefully the vacuum hoses there.
Start looking at these cheapest and easiest things first.
Good luck.
Denga
Old Oct 18, 2005 | 05:09 PM
BobbyR1972's Avatar
I think it's an electrical problem. The sensors like Wiking's writup suggests is probably the problem. Revolution sensor is # 1 on my list. Thanks Wiking. I'm going to do the self diagnosis tommorow to see what light stay on longer. I got my money on the revolution sensor.
Old Oct 19, 2005 | 02:01 AM
Wiking's Avatar
I think it's an electrical problem. ...
What do u do when this happens? Does tranny start to work after some time and u can limp home...?
Old Oct 19, 2005 | 06:49 AM
BobbyR1972's Avatar
I let off the gas and the RPMs come down and I press on it again and it's normal. But I can't climb hills well because I think there is a higher demand on the injectors also and the trans will hold in 1st past 3000 and not shift up. So the car is a dog right now. But I remember the days when I could easily get the car up to 125. 75-85 and I'm lucky. It has to be flat ground or downgrade.
Old Oct 19, 2005 | 07:00 AM
Wiking's Avatar
... So the car is a dog right now. ...
Measure also TPS; TCU (trans ctrl unit) uses that as input to gear change, see p6.
Old Oct 19, 2005 | 02:22 PM
Phatsta's Avatar
well everyone knows what I'd say so I wont say it
sounds just like you've got a slipping going on there
spencerwh1
Jun 30, 2016 05:44 AM
bryants95max
Oct 2, 2015 12:52 PM
carlosvq30
Sep 26, 2015 09:44 AM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
