hard to start problem
Old Oct 20, 2005 | 10:49 PM
wawa92gxe's Avatar
recently i have been having this problem from time to time trying to start.
There was no starting problem when i can hear the fuel pump buzzing noise.
Sometimes i couldn't hear the noise when i put the ignition key to ON position and that was when i was having trouble starting. Pulled the key out and insert again most of the time solved the problem.
Do i have a bad ignition switch or fuel pump relay? I am thinking i must have a bad connection somewhere.
Where should i look into first?
Thanks in advance.
Old Oct 21, 2005 | 12:15 AM
Wiking's Avatar
Originally Posted by wawa92gxe
...Where should i look into first?...
Trunk LH rear panel for relay, key sw for key sw, info from info↓
(if CarDomain isnt toady today)
edit: CD works just now, at your mid night moment...
here: http://www.cardomain.com/ride/748507/15
Old Oct 21, 2005 | 05:12 AM
internetautomar's Avatar
mod or sell?
check the connector at the fuel pump too. there have been reports (only 1 or 2 ) of the connector being bad
Old Oct 21, 2005 | 05:20 AM
dantegl's Avatar
Whens the last time you changed your plug's, wire's and distribitor cap. I had a similar issue and changed all that and the car fires up instantly now, plus it drives better than ever. atleast that was the case with me...
Old Oct 21, 2005 | 08:19 AM
wawa92gxe's Avatar
Have done a tune up last week. All plugs and distributor cap, rotor are new. Fuel filter as well. timing belt, water pump, all drive belts..
I am still thinking a weak electrical contact.
But after firing up, there is no problem. The car runs really smoothly.
It is only at the starting. Sometimes i could not hear the humming noise of the fuel pump.
I just checked the voltage at the fuel pump fuse when i did NOT hear the noise, there was still 2.54 Volts there.
I guess the problem could be at the relay.
Thanks much Wiking and internetautomart for the electrical info.
Old Oct 21, 2005 | 02:21 PM
mod or sell?
2.54 volts???
it should be like 12.54 volts
Old Oct 22, 2005 | 12:49 AM
Wiking's Avatar
2.54 volts???
Yes, get somewhere and pour in 10 volts more... careful to pour the exact.
Old Oct 24, 2005 | 08:50 AM
wawa92gxe's Avatar
I just re-test the voltage at the fuel pump fuse, it is still like 2.54 volts. The key was at ON position but not cranking position. The car is running very smoothly. i have cleaned out the fuel pump relay in the trunk and the connector. I found out there was a very loose vaccum hose on the fuel pressure regulator and replaced. So far have not got any difficulty in starting.
If there should be 12.54 volts ( i indeed also think so), where could the 10 volts drain?
Any other relay or connection under dash i should check?
Thanks a lot in advance.
Old Oct 24, 2005 | 09:08 AM
Wiking's Avatar
I just re-test the voltage at the fuel pump fuse,...
- oxidized, pinched wire and or short to chassis
- supply wire/connector transfer resistance
Add contact grease to justabout any relay/fuse/connector pins.
Take new (fused) wire direct from batt to relay. Leave orig fuse out.
Old Oct 24, 2005 | 12:09 PM
wawa92gxe's Avatar
how is the fuel pump fuse wired to?
I have tried to look at the wiring diagram but can't locate it.
Is it one end linked to ignition switch and the other to the relay in the trunk?
Thanks.
02PearlSE
Oct 7, 2015 02:12 AM
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
