Best sot to run Power cable
Old Oct 25, 2005 | 08:11 PM
Sgibb's Avatar
Im trying to find the best spot to run a 2 gauge wire off my battery to my trunk for my amp. Any good spots in the firewall?
ps any pics would be great
Old Oct 25, 2005 | 08:23 PM
maxitech's Avatar
You are probably going to need to drill your own hole...I did just north of the brake pedal
Old Oct 25, 2005 | 08:24 PM
Sgibb's Avatar
Was that a pain in the ***?
Old Oct 25, 2005 | 08:28 PM
AscendantMax's Avatar
i drilled a hole, while others used the hole where the hood release cable goes through the firewall iirc.
Old Oct 25, 2005 | 08:38 PM
Hectic's Avatar
between engine bay and fender where your other wires are running through. it's a rubber peice. it might not be big enough for 2 ga. whatever you do, be careful not to cut into the other wires. i ran an 8 ga through it and even that was sketchy. the rubber will constrict after you pull the drill bit out, take a nail or something and tape around the wire to make a lead and then just pull it through the hole. sorry, i don't have a pic.
Old Oct 26, 2005 | 04:39 AM
90pearlSE's Avatar
I ran a 4ga. wire through that rubber gromment. Used a drill guide to pick the bit, drilled the hole, sprayed a little wd-40 and it slid right through. The interior of my car was out at the time, and I just routed it down the driver's side and into the trunk through one of the holes on the rear deck (I think) so it followed out with the trunk release cable.
What kind of system are you running that you would need 2ga. wire??
Old Oct 26, 2005 | 09:31 AM
Mizeree_X's Avatar
Getting back to his roots
I've run 4ga through the same grommet, I just used a pair of needle-nose pliers to "bore out" a hole in the grommet itself (it is rubber so it is pretty easy). It was actually harder to get ahold of the wire once it poked through from the dead pedal side. 2ga, might be pushing it.
Old Oct 26, 2005 | 09:33 AM
Matt93SE's Avatar
STFU n00b!
http://blehmco.com/pics/car/interior/alarm/
Old Oct 26, 2005 | 09:46 AM
DanNY's Avatar
Ad·min·is·tra·tor
ran a 0ga into the rubber grommet and no problems
Old Oct 26, 2005 | 12:50 PM
nismosleeper's Avatar
Yep, use that rubber grommet. I put two 4 gauges through with little trouble. I did take off my fender to do it, although you should be able to do it w/o. Have fun
Old Oct 26, 2005 | 12:54 PM
aw89maxSE's Avatar
Kind of pain to get a drill in there, put I think I did mine northwest of the brake pedal....somewhere around there
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
