How do you stop clear coat peeling?!!
Old Nov 4, 2005 | 12:43 PM
Maxima Man's Avatar
I have allready posted in the detailing fourm and I am now coming to you great 3rd geners for help. And I tryed Already!
Any best way to repair a clear coat hole? The steps involved.........
OR Just how to stop the clear coat form peeling!!!
Thanks Guys
Old Nov 4, 2005 | 12:45 PM
Greeny's Avatar
¯\(°_o)/¯
Get a paint job......
Old Nov 4, 2005 | 02:06 PM
Matt93SE's Avatar
STFU n00b!
once it's started, there's not much you can do.
about all you can do otherwise is to carefully use a razorblade flat against the paint to remove any that's peeling up, then scuff-sand the area and spray it with some clear- enough to 'glue down' the peeling edges and seal it off to help it keep from separating.
If that doesn't work, then you get to repaint your car. :\
Old Nov 4, 2005 | 02:10 PM
Jeff92se's Avatar
I'm needing a caw
You could try to use clear fingernail polish to seal the ends of the peeling paint. But other than that, you can't really stop it. It's probably from a poorly done repaint and either the surface wasn't prepped or the base and/or clear is failing.
Old Nov 4, 2005 | 02:20 PM
CyMax's Avatar
Could you wetsand off as much of the CC as you can, and the hit it with some new?
Old Nov 4, 2005 | 02:28 PM
Jeff92se's Avatar
I'm needing a caw
Not without screwing up the metallic base coat (if that's the case) under it. Plus if the base and/or clear is failing it will just peel somewhere else.
Old Nov 4, 2005 | 07:42 PM
dtahsee's Avatar
I agree. Once the peeling starts there is not much that can be done. I have the same problem with my maxima, with the CC peeling off on the hood. Get a paint job if it bothers you too much, or else, do what I do, ignore it and enjoy the ride.
Old Nov 5, 2005 | 09:43 AM
Maxima Man's Avatar
It has just started a little nickel sized spot on the hood and I thought I should handle now before it gets out of hand! This is the only spot the clear coat is peeling and I wax regurly and I have clayed the car (it has good paint) what did i do wrong this is the worst thing(clear coat peeling)that i hoped detailing and waxing and cleaning the paint would prevent ! I will try razor to cut the peeled clear coat then buy some clear lacqer to cover it Any great clear coats in a rattle can ??
Thanks Guys
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
