Fixing Driverside Door-HELP
Old Jun 1, 2001 | 07:38 PM
maximusSE's Avatar
does anyone know how to fix the driver side door...(guess it would help if i told you what was wrong) um, it shuts weird, like it is a very harsh shut like the door is out of alignment, when you take the very end of it(like near the handle) you can move it up and down vertically, (that cant be good) thats about all i can tell you, any advice would be great
Old Jun 1, 2001 | 09:41 PM
DaBoxSE's Avatar
Aha!
Happened to you too, didnt it? I currently have the same problem. Your door hinges have reached their end. You need to replace both the top and bottom hinges to fix the problem. You can get the hinges at Courtesy Nissan for less than $30 I think for both of them. I have the hinges sitting in my room still and I bought them about two months ago, I just havent gotten around to doing them yet. I will soon though. If I get them done before you, I will tell you how it went and what to do. Later. Clark
Old Jun 1, 2001 | 10:55 PM
superdesi's Avatar
New Hinges?
I have that same problem only on the driver's side.
However, I always thought that it went out of alignment and all I had to do was to loosen the four bolts around the hinges, align it, then tighten them up.
I had no idea new hinges were the key.
Old Jun 2, 2001 | 01:21 AM
bigjay's Avatar
right but,
if it doesnt work, you go to the autoparts store and get shimms and bangem into place with someone pulling the door upwards as you do it, and dont forget you can adjust the stricker aswell(the part of te doorframe where the lock hooks into, is a "u"shaped latch which i believe has 4 arrows on it showing it's direction of movement)
Old Jun 2, 2001 | 04:41 AM
superdesi's Avatar
Re: right but,
Good idea Jay. Thanks.
Old Jun 2, 2001 | 07:04 AM
maximusSE's Avatar
does that mean i have to take the whole door off? crap thatll take a while! and where are they at courtesynissan.com? i cant seem to find them
Old Jun 2, 2001 | 09:57 AM
DaBoxSE's Avatar
Give Courtesy a call 800-527-1909. Let them know you need both hinges and they will help you out
Old Jun 2, 2001 | 09:08 PM
bigjay's Avatar
FOH SHO!
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
