A/C Temp. Slider
Old Nov 12, 2005 | 02:17 AM
kiyakerz's Avatar
A/C Temp. Slider
the air conditioner temperature slider is extremely hard to move back and forth, so usually i go from super cold to super hot because once you get it to move, the slider jerks to the opposite side since you put too much force on it. is there a way to loosen this thing up or something? I figured sliding it back and forth really fast might fix the problem, but I think i came close to breaking it.
Old Nov 12, 2005 | 03:00 AM
Greeny's Avatar
¯\(°_o)/¯
You need to hit up the junkyard for another one....
The slider runs on a little plastic track inside the unit. After years of sliding back and forth the little track warps,causing it to become stuck when you slide it across the warped spot...I took my parts car unit apart to try to fix it, but found no way to repair the track....You might get by for a while with some spray lube like lithium grease...But eventually it will stop sliding altogether...
I try to get some pics up of my parts car unit when i get home this afternoon to show you what it looks like....
Old Nov 12, 2005 | 03:02 AM
Wiking's Avatar
I suppose u mean the manual version ****...
Plastic **** sticks in plastic 'rail' [blu]. Spray/lubrication keeps it sliding...
view from below:
top/front view to the ****, more at http://www.cardomain.com/ride/748507/7
Old Nov 13, 2005 | 04:46 AM
Greeny's Avatar
¯\(°_o)/¯
Old Nov 13, 2005 | 05:51 AM
decus's Avatar
damn, thats looks pretty messed up. is that all just from warping? i'm guessing that this is more prone to hot climates
Old Nov 13, 2005 | 11:22 PM
Wiking's Avatar
Really, Saharan El Alamo battlefield... Cold nights, more sand than air!
tarun900
19
Dec 20, 2021 06:57 PM
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
