Need new door, couple questions...
Old Nov 17, 2005 | 07:28 PM
Wolverine's Avatar
I'm about to purchase a rear-passenger side door to fix my smashed Maxima. My maixma is a 92 SE, and the one i want to purchase is from a 91 SE- will that be a problem?
And what tools do i need to change the door???
Old Nov 17, 2005 | 07:30 PM
internetautomar's Avatar
mod or sell?
same ****. not sure on what tools you need though
Old Nov 18, 2005 | 09:03 AM
Wolverine's Avatar
great, thanks
Old Nov 19, 2005 | 12:27 AM
Wolverine's Avatar
anyone know about the tools?
Old Nov 19, 2005 | 05:15 PM
mod or sell?
ask colombianmax, he pulled the front door off my old max
Old Nov 19, 2005 | 07:16 PM
Michael's Avatar
Back in a 3rd Gen.
Its been a while so I am not sure but I think its 14mm (maybe 12mm) for the door hinges...just run out to your car and check. You will also need a small hammer to knock the pin out of the door slider thing (not sure what its called but its the thing that keeps tension on the door when you open it)...just knock it up and then take a small screwdriver or something and knock it the rest of the way out. Also a flat head screwdriver to use with the hammer and knock the hinge off. They use a seam sealer or something and its almost like glue and you have to seperate it from the car. Be sure and have somethign supporting the door so it doesnt hit the ground hard.
Now for the wires...DO NOT CUT THEM...you dont want to cut the harness but if you pull the weather plug where the wires go into the body you can pull the wires out and there is a plug that connects the door harness to the car.
Putting it back on will be fun...sometimes it can be a pain to get it adjusted properly. I always use a jack to hold it up and help align it.
Old Nov 20, 2005 | 10:59 AM
vansskaterfreek's Avatar
they are 14 MM.......4 connecting to frame..... i think i have pics of my froint door if you need pics
Old Nov 20, 2005 | 11:18 AM
Greeny's Avatar
¯\(°_o)/¯
12mm...
Old Nov 20, 2005 | 12:17 PM
shavedmax's Avatar
take them off the door side, not the body side unless there was damage to the hinge pilar. there is no adjustment from door to hinge, but there is from hinge to post. should make putting back on alot easier.( when you go pull it off at the jnk yard though take it off with the hinges in case they are damaged and you need them later.)
Old Nov 20, 2005 | 03:20 PM
Wolverine's Avatar
wow, thanks a lot guys. A lot more detailed descriptions and pictures and advice than I had hoped for. Really appreciate it, should make the job much easier.
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
