Need Install Help.....
Old Jun 3, 2001 | 10:31 AM
SilverBullet98's Avatar
I got new headlights and clear corner lights...Does anyone have instructions on how to repalce both of these ???
Old Jun 3, 2001 | 10:41 AM
Brandon90gxe's Avatar
the little book in your glove box called nissan maxima owners manual should help ya out! plus a lil commen sense, and your set. ahh im feelin lazy today, gimme a break.
Old Jun 3, 2001 | 11:31 AM
nubiannupe's Avatar
OG Maxima.org Member
Ahhh, Brandon! You so funny...
But dude, he's actually RIGHT! But just in case you REALLY wanna know....
The headlight bulbs screw out from the rear of the headlight assembly. A simple half-twist, and 'viola'!! Just don't put your fingers on the new bulbs, as that diminishes the life of 'em.
As for the corner lights, there's a screw/nut just a bit forward of the fender (under the hood, of course) that holds in the assembly. As the assembly sorta 'snaps' into place, you've got to use steady, even pressure so that you don't snap off the connector. Once this is accomplished, you should gain easy access to the bulb behind it.
And while you're at it, a little dielectric grease wouldn't be such a bad idea while you've got the connector out.
Good luck, and happy motoring!
Old Jun 3, 2001 | 02:32 PM
I'm not trying replace the bulb....The HEADLIGHT, not the bulb......And there is nothing in my owners manual, and also, if my question ****es you off, then dont answer it !!! Leave it for someone else who can help to answer !!
Old Jun 3, 2001 | 03:27 PM
C-Dawg's Avatar
I am not trying to be a smartass, but you should pick up a Haynes or Chilton's manual. These things are explained in step-by-step detail.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
