HEEEEEEELP tranny drain pug!!!
Old Nov 27, 2005 | 07:34 PM
Tonyklem's Avatar
well, ive just been in the garage for 4 hrs trying to figure out how the hell to get this plug out. every time i try a large screw driver it just slips out. i even got a jack and pushed the screw driver up onto the plug then tried turning it with an adjustable wrench. that just stipped it more ........
help me out. anyone else ever have this problem?
i was thinking of just drilling it out and retapping
Old Nov 27, 2005 | 07:47 PM
MrSector9's Avatar
There is a set of extractors you can get that fit on the outside of bolts/nuts made by snap-op and they work unbeleiavbly well.
Maybe try a chisel, get a good bite into it and try to spin it out
Old Nov 27, 2005 | 07:49 PM
disgruntled's Avatar
is this an auto or manual? I'm not sure about the auto, but on the manual, use your regular 3/4 ratchet, it will fit snuggly.
Old Nov 27, 2005 | 08:16 PM
Tonyklem's Avatar
its a manual.... 3/4 ratchet??? it needs a flathead not a socket.
Old Nov 27, 2005 | 09:35 PM
NismoChi's Avatar
You are trying at the wrong place, i made the same mistake, the drain plug is right by the pass side axle, can someone show him a pic from the FSM, (i've seen it on here before), BTW the filler plug need a 1/2 ratchet, not a 3/4 ratchet.
Old Nov 28, 2005 | 04:23 AM
my mistake.....had a brain fart.
Old Nov 28, 2005 | 06:43 AM
blackandwhite's Avatar
To them I'm like an idol
It's a manual....the drain plug is a 1/2 in ratchet in the front of the tranny, just to the right (as you face the car) and below the slave cylinder...it is a screw with no head, that simply has a 1/2 square hole for the ratchet.
Old Nov 28, 2005 | 06:45 AM
Mizeree_X's Avatar
Getting back to his roots
The FILL plug is a 1/2" female ratchet. The drain plug is near the rear of the tranny and is a metric bolt. Sheesh.
Old Nov 28, 2005 | 07:49 AM
Matt93SE's Avatar
STFU n00b!
the part you're trying to remove is one of the check ball holders. remove that and your transmission falls apart from the inside.
fortunately, you can't remove that thing without pulling the case off and removing a locking pin going through the tranny case.
next time, read the manual before attempting to do stuff like this.
Old Nov 28, 2005 | 02:07 PM
maxitech's Avatar
Old Nov 28, 2005 | 03:25 PM
CyMax's Avatar
On this same topic, while I was draining the tranny fluid to change Axles, I had a ballbearing and a spring about 1/4 in dia. and 1.5 inches long come out with the fluid!! So how long till I'll be rebuilding / replacing a tranny???
Old Nov 28, 2005 | 03:36 PM
Greeny's Avatar
¯\(°_o)/¯
...dude that sucks....some of you guys have the sh!tiest luck...
Old Nov 28, 2005 | 03:37 PM
CyMax's Avatar
Funny thing is it still shifts fine
Old Nov 28, 2005 | 03:45 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like a check ball fell out....
Old Nov 28, 2005 | 03:59 PM
joosdawg's Avatar
first time i ever drained my tranny fluid i also took the wrong bolt out, all of a sudden i saw a spring and ball start coming out lol. i got it right back in though. My tranny also has been shifting fine but what does that do?
Old Nov 28, 2005 | 04:01 PM
Matt93SE's Avatar
STFU n00b!
umm yeah... that's a check ball and spring. that keeps the tranny from goign into two gears at once. it's possible you can/will lock the tranny into two gears and royally **** the thing up.
better get that tranny off and take it apart and find out where those two guys came from.
Old Nov 28, 2005 | 04:02 PM
joosdawg's Avatar
so i should be fine then if mine never fell out? i got it right back in once i saw the spring starting to come out.
Matt93SE's Avatar
STFU n00b!
If you put the thing back in and the tranny still shifts fine, (I hope you put the ball in before the spring!), then you will be okay.. if the tranny didn't want to shift or had a problem, then that's when you have issues.
Old Nov 28, 2005 | 04:06 PM
Matt93SE's Avatar
STFU n00b!
yes, you should be fine.
I'm going to guess the one you removed was for 5th gear and reverse. it's on the front of the tranny not too far from where the fill plug should be.. the other two are farther away from it
Old Nov 28, 2005 | 04:09 PM
joosdawg's Avatar
i dont know if you were talking to me about the one i took out but, the one i took out was on the rear of the tranny because i thought it was opposite of the fill plug for some reason but this was a while ago. I just didnt think that the drain plug would be so darn close to the shift linkage and crossmember
Old Nov 28, 2005 | 04:19 PM
CyMax's Avatar
Ummm so if one were to have removed that and well if the ball and spring fell out, should one say just insert ball then spring back into tranny??
Old Nov 28, 2005 | 04:39 PM
Greeny's Avatar
¯\(°_o)/¯
Just say it cy,just say it..."I removed the the check ball screw to drain the tranny fluid"
Old Nov 28, 2005 | 05:00 PM
Matt93SE's Avatar
STFU n00b!
If you did that and didn't drive the car or shift the tranny, then you should be fine. put the check ball and spring back in and THEN see if the tranny shifts through all gears okay. if it does, then you should be okay. If it doesn't, then you're going to have to pull the tranny and separate the case, realign everything, then reassemble.
Old Nov 28, 2005 | 05:21 PM
vansskaterfreek's Avatar
ohh what fun would that be..........especially when it is getting cold outside... trust me.. its not fun!
Forge277
Jun 13, 2016 09:26 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
markevans999
Sep 10, 2015 04:29 PM
pktaske
Sep 4, 2015 08:40 AM
