Oil filte doesn't fit... has this ever happened to you?
Old Dec 12, 2005 | 08:38 PM
  #41
vansskaterfreek's Avatar
Originally Posted by disgruntled
Dude, if you don't get an oil change, you will have a very shiny, clean, and BROKEN engine in about a couple hundred miles, forget the 1500 miles figure. The seafoam stuff is primarily used to "flush" the engine free of grime and contaminants that had build up over the years, and have a very low lubrication property (think kerosene based engine flush,) plus, it was designed to BREAK DOWN oil grime, so think what that will do to your motor oil. So basically your engine will kill itself during cold start up, and will definitely kill itself during regular run. Also, I think vansskater is referring to heat lock, which happens to engine with no lubrication, and the heat generated from a running engine will evantually cause the metal surfaces to super heat so that it will literally melt and catches the piston in place, which in final means there will be a connecting rod going straight through the top of the piston, along with other goodies.
thats basically what i was saying... close enough..... dude to change your oil all you have to do is get a pan.. or bucket....unscrew a bolt (14 MM) and let it drain.. then change the filter which is unscrewing it with your hands and putting the new one on.. when you out the new filter on.. make sure you wet the rubber seal with some fresh oil then screw it back on.... dont overtighten..... it is so easy youll beat yourself.... it is a 10 minutes job for beginners... u should try it before you f- something up
Old Dec 13, 2005 | 06:25 AM
  #42
wutsup
i added STP Oil Treatment to get the thickness up. im gonna ask my dad if i can get an oil change today. my car has over 200,000 miles. thx for replying guys
Old Dec 13, 2005 | 07:14 AM
  #43
nismos14's Avatar
§è~® f®ÈÄk
WHY THE HELL DO YOU HAVE TO ASK SOMEONE IF YOU CAN GET AN OIL CHANGE???? Just freakin go get it done!!
Old Dec 13, 2005 | 08:03 AM
  #44
MyBlue92Maxima's Avatar
lol do it yourself .. i use 10w30 / 10w40
Old Dec 13, 2005 | 09:52 AM
  #45
disgruntled's Avatar
We don't know his situation, but c'mon about 14 bucks total for a decent oil change that will save you hundreds if not thousand is a good investment is it not? Plus, if you are new to the whole car thing, don't be afraid to ask, that's what the forum is for.
Old Dec 13, 2005 | 10:11 AM
  #46
maxitech's Avatar
We don't mean to give you a hard time, it's just that oil is one of the cheapest, easiest, and most important things to pay attention to...and none of us want to see you blow your engine due to highly preventable circumstances. Happy Holidays!
Old Dec 13, 2005 | 11:59 AM
  #47
nForce's Avatar
The Computer Guy
lol this is crazy just read liek all these posts. who uses liek 20 50 and 0 30 crazy? sounds liek someones gonna screw there engine. I only use 5 30 all yr and change it about ever 2800miles or 3 months. I do add some additve every once in while. But still runs good with 124k on it.
Old Dec 13, 2005 | 01:16 PM
  #48
wutsup
hey thx for replying. i got my oil changed today so you guys dont need to say anything now. thank you
Old Dec 18, 2005 | 05:24 PM
  #49
slickblack94's Avatar
RECORD HERE:::::: changed my oil in 17 mins with a air filter change. put on the toyo filter and mobil 10-30 5000 mile oil. anyone faster? clock it lol
Old Dec 19, 2005 | 02:28 AM
  #50
alextothestars's Avatar
it can be done quicker, but really isnt that good of an idea since you want to get all of the carbon/dirty oil out that you can get out of it
Old Dec 19, 2005 | 12:00 PM
  #51
VEvolution's Avatar
I miss my VE
Any of you high mileage guys ever stop to think that even though 5w is good for the winter, it's not thick enough for a worn engine? That stuff is recommended when your car is new. After 100k or so, you really think you should still be using that?
Old Dec 20, 2005 | 09:05 AM
  #52
maxitech's Avatar
12 min w/o air filter
Old Dec 20, 2005 | 09:08 AM
  #53
maxitech's Avatar
These engines don't exhibit symptoms of wear nearly as much as many lesser engines, usually. Some of these guys run mobil 1 or other synthetics.
Old Dec 20, 2005 | 09:12 AM
  #54
Greeny's Avatar
¯\(°_o)/¯
Bah!....My car has had 5w30 it's whole life with no problems...
It has almost 290,000 on it now....
Old Dec 20, 2005 | 09:29 AM
  #55
VEvolution's Avatar
I miss my VE
Hm, I see. Good point. Synthetic is definatly heavier and clings better to parts. So 5w in synthetic mode, would be cool I guess. I'll use that when I switch over to synthetics in about a year or so.
Do you go everywhere with that camera?
Yeah, I guess it's okay. I'd bet if I had that mileage, I could pull off a better compression since yours would be owned a bit more from all those cold winter 'thin oil like water' starts
Old Dec 20, 2005 | 10:56 AM
  #56
Greeny's Avatar
¯\(°_o)/¯
Camera? What camera??
Think about it..Don't you think that if the oil i have been using was damaging my engine it would have shown a sign by now?? My car does not smoke,leak or show any signs whatsoever that it has internal damage from the oil i use...I can still get on it from first to second gear and catch rubber every time..
Old Dec 20, 2005 | 11:32 AM
  #57
VEvolution's Avatar
I miss my VE
Damn, I guess there really is no difference...
Edit: But in theory, you do know you normally should increase the start up weight a bit for older worn engines. Says so in my tech book.
Old Dec 20, 2005 | 01:07 PM
  #58
mtcookson's Avatar
thicker oil for ye old pushrod v8's and not so reliable engines. ours are ok.
Old Dec 20, 2005 | 02:09 PM
  #59
maxmaxima91's Avatar
I run full synthetic 10w40 all year round.. works great. Untill you get into the Really cold weather and Really thick oils i dont think theres much to worry about along those lines (10w, 15w40). One of the big reasons manufactures recommend thiner oils,is that it can slighty improve gas millage. Thiner oil = less parasitic loss.
I like a bit thicker oil, it makes me feel better, figuring i drove my car REALLY hard for 60k miles and then i turboed it. Thicker oil will fill up the clearance in a slightly worn bearning better than thin oil. I run synthetic because of the turbo, its not watercooled so synthetic will take the heat better.
Jeremy
Old Dec 20, 2005 | 03:04 PM
  #60
internetautomar's Avatar
mod or sell?
15w40 is diesel oil.
though it does help reduce oil burning in cars that burn oil
Old Dec 21, 2005 | 07:55 PM
  #61
jaymez619's Avatar
I had an autoshop change my oil/filter once as part of a major tune up. The next time I changed my oil, I found that he used some cheap aftermarket filter that was smaller than the stock dealer filter which I normally use. The tool I use to remove the filter (looks like a giant rachet socket that fits perfectly on the filter) was too big for the cheapie filter. Luckily, I had this "boa constrictor" tool laying around. Imagine a lever with a rubber belt attached that you wrap around the filter. Anyways, even with the boa tool, I ended up denting the filter while removing it. I guess they put it on real tight. Here in warm Southern Cali, I use 10w-30 Castrol Synthetic Blend.
DJLAX152
May 4, 2021 11:46 AM
97_GXE
Sep 15, 2015 06:47 AM
Bonka
Sep 14, 2015 11:18 PM
ag90fox
Sep 9, 2015 12:22 PM
