brake fluid (for clutch)
does it matter which kind of brake fluid i use for the clutch?
My car has over 200,000 miles on it and in the owners manual it says to use conventional oil of API SG 5W30 Energy Conserving. I heard Synthetic oil is better for high mileage cars and i was thinking about switching on my next oil change. could i do that even if it is a different API and not energy conserving, but its still going to be 5W30? i just want some advice thanks.
hi guys im wondering is it difficult to fit a cone filter over the stock air box? and does it give you more power?
Can someone tell me how to rev match exactly. Lets say your going from 3rd to second gear. Do you rev when your in 3rd gear and then change gears to second? or do u change gears first and then rev then start to release the clutch?thanks
is this product worth it? and does it fit into the stock intake for the VG30E. i know you have to take out the stock airbox, but is it difficult to install?
http://stillen.com/Sportscars_detail...d=48137&page=1
Originally Posted by MyGreenMax94
My guess is the heat From the brakes burns the fluid...Hence the discoloration...
sorry...i meant for the clutch MC...i thought it was heat but i figured it never happens in my brake MC so why does it happen in my clutch MC and clutch heat can't be anywhere nearly comparable to brake heat...
Might as well just merge most of these posts
I love the merging option now
![smash](https://maxima.org/forums/images/smilies/smash.gif)
![easter](https://maxima.org/forums/images/smilies/eastersmiley.gif)
I have always used 10W30. As far a synthetic vs. regular goes, I find that Mobil1 works a little better for my VE engine, but when I had a VG like yours, I tried both and settled on the "high-mileage" half-synthetics made by castrol or mobil.
http://www.cardomain.com/ride/211217
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
HerpDerp1919
09-29-2015 02:02 PM
