Alarm led hook up to where?
Old Dec 21, 2005 | 02:32 PM
Dougn's Avatar
I got one of the Flashing alarm led and ready to connect to my existing Alarm system on the 92 GXE. The diagram showns one goes to 12v+ contant or battery +. I found this ok. The second wire should goes to 'The alarm system's accessory output'. Any one knows what wire (color) is this on the harness to the alarm unit located the left of the steering column. Optionaly where else can I connect the second wire from the led light to?
Old Dec 21, 2005 | 02:57 PM
Dougn's Avatar
Ok. I know how to ask the question now. Any one got a '91 Vehicle Wiring Information? Also is there an alternative for the 12V+ contant and 'alarm system's accessory output' that I can use to hook the led wires up.
Thanks.
Old Dec 22, 2005 | 12:53 PM
Dougn's Avatar
I finally got hold of the Alarm wiring diagram and figured it out. The stock alarm in my max does not have 'alarm system's accessory output'. At least I could not find it in the schematic. So I hooked it up this way:
1) Pos. wire from the led light goes to slot 1 of the Alarm control system's harness (12 V+ constand).
2) Neg. wire from the led light goes to slot 16 of the Alarm control system's harness (ground)
3) The third wire (yellow) from the led light goes to slot 3 of the Alarm control system's harness (Ingition)
The led is blinking now. Notice that this set up works without alarm system.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
