5spd is whining
Old Dec 27, 2005 | 11:02 AM
ArcticDC5's Avatar
5spd is whining
When I have the car in gear and moving, I can hear the transmission whining literally. I thought it was the p/s pump, but the wining goes away once I push the clutch in or have it out of gear but with the shifter pushed to the left or right (as if I was to go into 1-2 or 5-R). I had the trans fluid changed when I did my clutch about 8 months ago.
Maybe the trans fluid is low? Whats the best way to check the fluid level?
Old Dec 27, 2005 | 11:13 AM
Greeny's Avatar
¯\(°_o)/¯
The input shaft bearing is going out....Common problem with the maxima manual tranny.....
Old Dec 27, 2005 | 03:48 PM
subs1000w's Avatar
to check the fluid level remove the fill plug and stick your finger in there and if you feel fluid your proboly fine but if you dont low and even if you fill it back up the damage is already done
how many miles are on your trans
Old Dec 27, 2005 | 05:04 PM
ArcticDC5's Avatar
I think the trans is the original (171k)
Old Dec 27, 2005 | 05:52 PM
subs1000w's Avatar
that pretty much explains itself then
Old Dec 27, 2005 | 07:12 PM
ArcticDC5's Avatar
Alright, I know how to pull a tranny out.
My next question is what is involved in a tranny rebuild and what special tools will I need if any?
James92SE
142
Jan 2, 2024 09:23 AM
ef9
Oct 4, 2015 08:43 AM
homewrecker
Sep 24, 2015 07:01 PM
220k+ A32
Sep 11, 2015 02:18 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
