clunking from drivers front tire area...
havent taken the tire off to check things out yet, just thought id post a quick question about things to suspect and check.
clunking mainly when turning wheel left or upon deceleration but does clunk occasionally at speed as well...
suspecting maybe a wheel bearing? what else to look at/address?
maybe a front u-joint? front wheel drive cars are new to me...
thanks! brake pads in front are GONE so changing those 2night!
-Roo
-Roo
should i suspect the outer or inner?
whats the best way to actually check once i have the car off the ground and the tire off?
any other good sources of parts other then allnissanparts.com? this car has around 60,000 miles on it... i dont want to be replacing stuff like this already!!
-Roo
-Roo
the easiest thing to do is just replace the whole axle you can get one from any parts store for 60-100$
well i dont know how to check the axle with the tire off the ground only like you said if it clunks around a turn its almost always the axle and its a very common problem ive replace a whole bunch on many dif carsincluding 3 on my own
boomerbrian
11-08-2015 05:10 PM
Starrider
09-17-2015 07:26 AM
KGMtech
08-18-2015 09:21 AM
