Rev Matching
Old Dec 27, 2005 | 10:04 PM
subs1000w's Avatar
you rev while shifting ie clutch pushed in moving the shifter from 3rd to 2nd
practice and youll do it so fast you wont even notice
Old Dec 27, 2005 | 10:55 PM
95turbo gxe's Avatar
dam I was wondering what that was too. but i already do that or something like it
Old Dec 27, 2005 | 11:34 PM
Hectic's Avatar
it's the term used for shifting while clutch is engaged.. 3rd to second would consist of pulling out of 3rd, revving 1k or so rpm greater and throw it in second.. pretty pointless, it comes in handy while accelerating though, or rolling stop signs
Old Dec 28, 2005 | 12:27 AM
Maxpwer's Avatar
No turbo, no care!
Its used in non syncro transmissions. In most modern transmissions, we have syncros which allow gears of unmatched speeds to engage smoothly. In non syncro transmissions, the engine speed must be matched to the speed of the particular gear you wish to engage or the gears will simply grind. (Some larger desiel engines still uses these transmissions).
The only real advantage this has on modern syncro transmissions other than less drive shock, and glass smooth shifts, is control. On a wet road, a downshift without raising the rpms can break the tires loose by underspeeding them which can be enough to start a slide.
Old Dec 28, 2005 | 06:58 AM
blackandwhite's Avatar
To them I'm like an idol
It also comes in handy when clutch cylinders and/or throwout bearings have failed and you are away from home.
Old Dec 28, 2005 | 08:29 AM
Phoenix's Avatar
Lives in a Maxima
the 240SX is pretty picky about rev matching, only becuase when you disengage the clutch, you get a thunk in the differential if you do it wrong. Drive a 240 for a few years and you'll have it down.
Old Dec 28, 2005 | 08:35 AM
Yicco's Avatar
Old Dec 28, 2005 | 10:30 AM
wutsup
arite thanks for the tips. if i rev it first and then change gears will that work? or vice versa or do i HAVE to rev while im switching gears?
Old Dec 29, 2005 | 08:25 AM
MaxKlinger's Avatar
Obviously the clutch has to be in (disengaged) for you to be able to rev the motor...
Gently blipping the throttle to rev match is easier on the transmission overall. Definetly makes things smoother - just don't rev the crap out of the engine (you shouldn't be revving over 3500rpm on a regular basis anyway).
I do a similar thing with my automatic - if I decide to manually downshift the auto, I always making sure to press lightly on the gas while doing so. It does it so much smoother and with less strain on the car.
Old Dec 29, 2005 | 01:33 PM
AscendantMax's Avatar
so what's the difference between this and heel-toe?
(sorry for the newbie question...hardly know crap about mechanical stuff)
Old Dec 29, 2005 | 01:46 PM
goon9's Avatar
going from 3rd to 2nd I usaully
-clutch
-gotto nuetral rev up to match
-clutch and drop into 2nd gas hard!
Sounds frikn awesome when done quickly!
Old Dec 29, 2005 | 02:21 PM
MrGone's Avatar
1. you need a flywheel
2. you don't really stop in neutral, you're just passing through
It's generally
1. clutch in
2. shift and blip or blip and shift
3. clutch out
< .5 seconds
Old Dec 30, 2005 | 09:54 AM
Maximan190's Avatar
<3 heel-toe <3
Old Dec 30, 2005 | 06:53 PM
Alex_V
your crazy!
~Alex
Old Dec 30, 2005 | 07:29 PM
kcidmil's Avatar
Forget that... the good old power shift from 2nd to 3rd. Who needs to feather gas when you can keep it planted.
Last time I did that, I burned the tires for a good 50 feet, and drifted into oncoming traffic.
Old Dec 30, 2005 | 07:34 PM
steven88's Avatar
Need A Light?
you have the brakes applied then rev match....during a heel toe downshift...a regular rev match downshift will not have the brakes applied
Old Dec 31, 2005 | 01:46 PM
mtcookson's Avatar
Oops... I probably redline everyday and rev match between 4,000 to 5,500 a lot... (on the MR2 that is). I'm not sure what rpm's I went to on the Maxima when rev matching.
REDinLV
Aug 15, 2024 12:30 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
TheMafia
Sep 4, 2015 08:26 AM
