inflating tires having to do anything with steering problem?
Old Dec 30, 2005 | 07:54 PM
wutsup
i inflated my tires a few days ago and now the steering wheel feels stiffer turning to the left and it seems looser turning to the right. anyone know what the problem is. and sometimes when you turn the wheel a little bit to the right it doesnt turn unless your turn it more
Old Dec 30, 2005 | 08:01 PM
kcidmil's Avatar
If one tire have more air than the other, it could cause your steering to feel lopsided you like described. This is due to the fact that one tire is larger in diameter than the other, making it so the tire has to travel farther to complete one rotation.
THOUGH... the pressure difference has to be pretty far apart to notice something like that.
Your problem sounds more like a worn tie rod end, or rack and pinion.
Old Dec 30, 2005 | 08:17 PM
disgruntled's Avatar
sounds like a rack and pinion to me, had those same symptoms.
basically, after you make a turn, it will tend to "bind" to one side, so say you were making a left, then go straight, the steering wheel will return to the normal position, but then you make a right turn, then straight, now the steering wheel will sit crooked to one side, and if you jerk your steering wheel the opposite way, it will return to the neutral position, but the car will not jerk when that happens. Hope you kinda got my point.
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
