Big Repair Job on my Max
Old Dec 31, 2005 | 05:04 AM
swowlinc's Avatar
1993 SE
(long story short) Oil pan gasket went on strike and I almost ran out of oil. Put oil and Lucas oil stabilizer in and the car is ticking like a school bus now. I was told I need to replace my cam/timing chain tensioner at or around $3k. If so, Im thinking engine swap or rebuild another and put it in when this one fails. I just wanted to make sure it's not the VTC's before I make a decision. Will the engine from a 94 j30 work in these cars? Cause these mechanics are saying they could do it. The car still drives very well, but when Im idling at a light or something, there's this tick-tick-tick-tick.... Please help.
Also my clutchmasters stage1 chatters like hell till I push in the clutch, also when i downshift at any rpm over like 3k theres a chattering i dont like. I was told the first issue was normal, but I still dont like it. Any info there would also be appreciated. HELP.
Old Dec 31, 2005 | 05:21 AM
DaWifey's90's Avatar
what can my max do for me
did the clutch and engine noise both happen at the same time?
Old Dec 31, 2005 | 06:10 AM
Cliff Clavin's Avatar
Way out West
j30 engine won't fit. It is a VG30DE
If you search around, you can get a JDM VE30DE (same engine you have now) for under $1k. Unless you put it in yourself, it will probably be another $1k to have it installed.
There is a thread in the stickies about doing the JDM swap. There are a few minor things you have to do to get it to run right.
Old Dec 31, 2005 | 09:13 AM
swowlinc's Avatar
1993 SE
did the clutch and engine noise both happen at the same time? Nope. Im looking for a low mileage VE to build and swap then. The labor for that job is only $650...big difference. I wonder if I could find a VE turbo-ed already??? Thanks for the input.
Old Dec 31, 2005 | 01:47 PM
goon9's Avatar
Your pushing your luck.
Old Dec 31, 2005 | 04:43 PM
Way out West
Exactly what do you mean by "build and swap" for $650?
Do you mean they will fix your current engine or actually rebuild it?
Old Dec 31, 2005 | 05:09 PM
swowlinc's Avatar
1993 SE
Nah... I'll buy a whole 'nother engine, they will charge $650 to swap it. I could pay a lil bit more and do some things to the engine before I put it in. The power is still there though so Im not complaining. Whos got a spare VE?
Old Dec 31, 2005 | 06:04 PM
vansskaterfreek's Avatar
i have a broken one.... great for a rebuild.....but you probaly arentlooking for a rebuild
Old Dec 31, 2005 | 06:14 PM
Way out West
If you are going to spend the money to have it swapped in ($650 is a pretty good deal, BTW) I would just search for a JDM engine. I doubt you will find a used junkyard engine with less than 100k miles. Most JDM engines have little or no VTC tick and allegedly are around 30-60k miles and the places warranty them. Mine had a one-year, unlimited mileage warranty and it runs great. It has a little bit of VTC tick, but not much.
You or your mechanic should do some things while you have an engine out, too, no matter if you get one from a junkyard or a JDM.
Replace the exhaust manifold studs, new water pump, replace the belts, gaskets and hoses and swap over your 5-speed intake plenum (unless somehow you find a used 5-speed engine).
The information in the JDM swap instructions (general maintenance sticky) is good for any kind of VE install you do.
once again...straight outta the stickies...
http://car-part.com/index.htm
do a search....there's a healthy range of motors in the DC area...from 1500 to 200
Vequity
Sep 10, 2015 05:26 AM
dcam0326
Sep 8, 2015 11:02 PM
videomano
Sep 8, 2015 03:28 PM
sdotcarter
Sep 2, 2015 09:53 PM
