254xxx miles and now the car is at its last breath
Old Jan 7, 2006 | 07:47 PM
fatboyslim86440's Avatar
well i went to go wash my car today and noticed it had no power what so ever and a ticking noise under the hood no not the VTCs
came home popped the hood and pulled both valve covers off
saw that my rear timing chain has been grinding against something
since i have got the car in peices
what should i get and where
my timing chain tensioner is sticking soo thats 55 bucks
my timing chain is bad now another 23 bucks
figured i would replace the oil pump, water pump and some other stuff
i need some help on what i should get to get my car running better
i will try to get pictures tomorrow
thanks
Kyle Cisneros
edit: i know a guy that is selling his VE for 300 bucks with 170k on the motor
might end up buying that and freshen it up
yall are not helping me here
what should i get while the motor is torn apart
Old Jan 8, 2006 | 07:07 AM
internetautomar's Avatar
mod or sell?
Rebuild the VTCs while you're at it
Old Jan 8, 2006 | 07:14 AM
Scope's Avatar
Im izz sexay
Just thought I'll add this in VG30DE pistons, Total Seal rings, and ARP rod bolts.
Old Jan 8, 2006 | 08:59 AM
Matt93SE's Avatar
STFU n00b!
be sure to replace the idler pulleys for the timing chains too. they run on a copper bearing/bushing that's lubed by oil. when that thing wears out, it causes the timing chain to get out of alignment and rub on stuff.. probably the cause of your problems.
replace everything on the front end of the engine.. all three chains, bearings, idlers, tensioners, etc. rebuild VTCs or replace.
If the compression is good on the engine, don't bother tearing it down unless you have signs of metal shavings in the engine. might want to pull a cuple of the cam bearing caps and look for any scratching there. it's a quick and easy way to tell if there's any major damage in the engine. if it hasn't hurt them, then the rest of the engine should be okay. just be sure to flush out all the oil gallies you can while you have the front end apart.
Old Jan 9, 2006 | 11:46 AM
Pervis Anathema's Avatar
IIRC, my motor has ~145k on it. Is this type of maintenance something I need to worry about right now?
Old Jan 9, 2006 | 03:10 PM
eric93SE's Avatar
The oil pump isn't easy to get at, so I'd scratch that one off Unless someone knows otherwise.
Are you looking to fully rebuild or just get it going again?
Old Jan 9, 2006 | 05:29 PM
well since the top of my motor is open
i figured we would replace the oil pump any way
chains and tensioners have to be replaces sooo it wouldnt matter how hard it would be
just wish there was an easier way to get to the oil pump
thanks
i will get pictures soon of the rebuild
Kyle Cisneros
Old Jan 9, 2006 | 05:59 PM
Scope's Avatar
Im izz sexay
Might as well pul the engine to make life a lil easier.
Old Jan 10, 2006 | 12:54 PM
MaxKlinger's Avatar
See how quickly this just jumped from thinking ahead for preventative maintenance to total rebuild?
Old Jan 10, 2006 | 01:38 PM
where is the oil pump at on our VE motors?
how hard would it be to replace the tensioners and the chains too?
also
where is the water pump too?
thanks
Kyle Cisneros
edit: also i was wondering if any one had any sort of diagram for the vtcs??
Old Jan 10, 2006 | 04:58 PM
rteenie22's Avatar
some guy is sellin a se (ve powered) where i live with 354k miles on it. he says it runs good and its the original motor
Old Jan 10, 2006 | 07:53 PM
eric93SE's Avatar
also
thanks
Kyle Cisneros
wow dude, you don't even know where the water pump is!? You had better get yourself a FSM and do some reading.
Old Jan 10, 2006 | 09:10 PM
well i have never bothered with the motor
last time i did i almost fried the vtcs soooo
sorry
yes i do have the fsm on here
i just got to find it
but thanks yall for giving me ideas to get
Kyle Cisneros
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
WeetoddA32
Aug 16, 2015 12:45 PM
MikesChevelle
Aug 10, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
