do i have a bad injector?
Old 01-08-2006, 08:40 PM
Jeff583's Avatar
I was on my way home tonight and as i was leaving a stop sign I noticed that my engine was runnin a little odd. So after listening to it more closely I noticed that it is a small misfire, it only does it on the lower end, 1,000 to about 2,600 rpms. Also it is not a constant repetative miss it just kinda does it when it wants and only when im leaving from a stop or driving fairly slow, going down the highway at a constant engine speed seems to be normal with no miss and does not miss if i accelerate, only at lower speeds. Not sure what it could be cause i havent had an injector go on a VE, on my 89 it had a miss, then i cleaned the injector electrical connectors and solved my problem. I dont know when the injectors were replaced if they even where, but it has 194.xxx so it is probly due.
If anyone has any ideas let me know.
Jeff583 is offline
Old 01-09-2006, 05:27 AM
mod or sell?
internetautomar's Avatar
sounds like what my max did when I got it
7 injectors later it ran OK.
internetautomar is offline
Old 01-09-2006, 05:46 AM
CnR's 90 max's Avatar
injector cleaner, does it help or does it hurt?
CnR's 90 max is offline
Old 01-09-2006, 05:59 AM
mod or sell?
both
it hurts because it strips the coating of the coil in the injector
it helps because until the coil goes bad you've got less grime in the injector
Old 01-09-2006, 06:03 AM
both
my maxima as of today will not start, it cranks, but will not start. I can smell gas and just changed pvc valve the day before. could the cleaner caused the injectors to go bad? my max has 230k miles on it now i baught it with 215k miles.
Old 01-09-2006, 08:10 AM
wawa92gxe's Avatar
Have you checked your spark?
wawa92gxe is offline
Old 01-09-2006, 07:28 PM
yeah....It got me pretty good.........
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
chisam14
11-06-2018 08:56 PM
RealityCheck
10-02-2015 06:34 PM
Andy29
09-29-2015 05:32 AM
Quick Reply: do i have a bad injector?
