making the gears smoother with synchromesh fluid
Old Jan 10, 2006 | 06:04 AM
wutsup
where can i buy some of this stuff to make the synchros smoother and how would i put this stuff in. thanks
Old Jan 10, 2006 | 09:08 AM
Dillbag's Avatar
Suprise butsechs!!!
you mean GM synchromesh fluid? i've heard it's pretty good.
check the fluids/lurication section on the main menu.
Matt....?
Old Jan 10, 2006 | 12:47 PM
acidspit86's Avatar
whatever you do make sure its GL-4 fluid. and ive noticed that switching to 75-90w redline manual tran fluid makes a giant difference...
Old Jan 10, 2006 | 06:59 PM
subs1000w's Avatar
you can buy penzoil sycromesh at the zone for 6$ a quart which is half what GM dealers get and ive read on several ocasions GM buys the stuff from penzoil and renames it, i run it in both my trucks and they shift much better then with the recomended ATF but im not sure if id run in in a max since it could be thinner than 75w90
Old Jan 10, 2006 | 10:09 PM
Dillbag's Avatar
Suprise butsechs!!!
yeah, could be...
the fluids section has a good stickie about manual trans. oil.
I'll be trying Redline MT-90 soon, as i have a leaky axle seal to change.
Old Jan 10, 2006 | 10:10 PM
Dillbag's Avatar
Suprise butsechs!!!
alot of times just putting in fresh fluid can make a noticeable difference.
Old Jan 12, 2006 | 11:31 AM
wutsup
how do u check the transmission fluid level? i cant seem to find the dip stick. is it because its a manual transmission?
Old Jan 12, 2006 | 11:44 AM
Pervis Anathema's Avatar
Yes. 5spd = no dipstick. You drain and fill through the same hole. It is the bolt with a 1/2" wide indentation on it. Just use a 1/2" drive ratchet to take it loose. You only need to worry about your fluid level when refilling it. Also, I suspect that severly worn transmission mounts could cause you grinding issues as well.
Old Jan 12, 2006 | 06:36 PM
wutsup
so where exactly would the drain plug be for the transmission on a VG30E? i looked in the fluids and lubricants sticky but the drawings were to vague. thanks a million
Old Jan 12, 2006 | 06:54 PM
Greeny's Avatar
¯\(°_o)/¯
Actually, the drain hole and fill hole are separate....
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
