Why I hate the winter...
Old Jan 14, 2006 | 06:45 AM
CyMax's Avatar
Ok so now the Axles are FINALLY done. Working till 4 or 5 PM with no lighting for later, and having at least half of the weekend taken by football / hockey / or the Fiancee, this has taken forever!! Thanks to thoes of you who helped with advice or with the part, ( thanks for the Ball!).
After checking both ends for the propel double threads and size:http://i32.photobucket.com/albums/d3...G_0241_1_1.jpg
both ends
http://i32.photobucket.com/albums/d3...G_0242_1_1.jpg
Here is the part# for Carquest
http://i32.photobucket.com/albums/d3...G_0247_1_1.jpg
The first axle I got had a 28 mm nut that barely held on this is how the right one should look http://i32.photobucket.com/albums/d3...G_0245_1_1.jpg
Now the hub is comming back from the machine shop getting a new wheel bearing pressed in. Lesson there, be gentle with the air hammer.
Old Jan 14, 2006 | 08:22 AM
maxitech's Avatar
What were you doing? Replacing the axles?
Old Jan 14, 2006 | 09:27 AM
CyMax's Avatar
Yes, both CV joints were going pretty bad, so what the heck I'll do it and save $$. Well I did but damn the time. Just MAKE SURE YOU HAVE THE RIGHT PARTS!!! Oh and when you drain the tranny, use the drain plug, not the plug holding in the 5th/R check ball & spring. Nothing like watching a little metal ball go bouncing down the driveway into oblivion.
Old Jan 14, 2006 | 03:03 PM
Greeny's Avatar
¯\(°_o)/¯
I still have your check ball boxed up ready to go...
Old Jan 14, 2006 | 04:08 PM
todamax's Avatar
hehe, I've been known to just pull the axles and let the tranny drain that way.
Old Jan 14, 2006 | 06:12 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
tell me about it. gotta do axels on my 99 im not looking forward to it.
Old Jan 14, 2006 | 11:45 PM
todamax's Avatar
Its not that bad. If you are handly with a wrench, and find no frozen bolts, it can be done in 2 hours.
Old Jan 15, 2006 | 12:20 AM
Maxzilla91's Avatar
... u're making me too comfortable at tackling this job myself.
Old Jan 15, 2006 | 01:17 AM
4dscPat's Avatar
the hardest part is those 3 bolts holding the passenger axle bearing carrier. You just need a selection of extensions, and a u-joint would be beneficial. Other than that, it takes like 15 minutes per side. The 3 bolts may take another 15-20. The driver side is really easy. Just undo the 2 bolts holding the strut to the knuckle, undo the axle nut, and pull it out.
Forgive any grammer errors, poster is intoximacated
Old Jan 15, 2006 | 07:16 AM
vansskaterfreek's Avatar
since you are replacing the passenger axle... when i did it i used a pry bar and a hammer..... but i also took the y-piip off.. it gave me lots more room... there is 3 17MM bolts that hold the strut to the knuckle..... you DONT have to take the steering control arm off! the axle nut is a 36 MM nut... make sure you have a nice breaker bar and a nice pipe on the end of it.. they are really on there.. make usre you hold the end of the wrench with one hand and PULL up with the other so you dont snap the head of the wrench off.. trust me i did it... but it was craftsman.. if you need any help PM me
Old Jan 16, 2006 | 01:23 PM
CyMax's Avatar
My computer died around the first, so I just broke down and paid the 3$ at the Dealership nextdoor. Thanks for the 2nd attempt tho. I really do appreciate it.
Old Jan 16, 2006 | 01:25 PM
CyMax's Avatar
My bearing was froze, all it took was 1 second with an air hammer . Tap tap tap zing and off it was. Damn parts was the only sticking point.
Old Jan 16, 2006 | 03:15 PM
KD Camel's Avatar
I think you gotta be pretty handy with a wrench to do it in about 2 hours. but I suppose experience teaches alot. I did the right transaxle about a month ago and lazily decided to put off the other side (where the boot was not yet torn) until the spring (yeah, I like warmer weather). unfortunately I noticed todays that the left transaxle (driver side) is now torn with the grease all over. I have a '90 auto maxima that I just purchased about 2 months ago. does anyone know, do I need to drain the tranny fluid for the left side like I did for the right side? also is it a pure pain in the butt like the right one was. I'm okay with taking the knuckle off and the hub nut. I just remember sittin under the car for over an hour using a wrench in the trickiest of spots to make 2 inch wide turns until I got some bolts loosened and then retightened afterwards. does the left side just pry off with a screwdriver or is it also bolted?
Old Jan 16, 2006 | 07:04 PM
the drivers side is just sitting in there... just give is a good pull... there is a little clip on the end of the axle to get it out... just tug really hard and itll come out
Old Jan 16, 2006 | 08:45 PM
todamax's Avatar
Originally Posted by KD Camel
does anyone know, do I need to drain the tranny fluid for the left side like I did for the right side? also is it a pure pain in the butt like the right one was. does the left side just pry off with a screwdriver or is it also bolted?
Well you remove the left side drain plug. Don't get it mixed up with the right one or the one for the halogen fluid though. Now that would be a mess.
The left axle will pull right out, no intermediate bolts.
Old Jan 17, 2006 | 12:54 AM
Phatsta's Avatar
Theres a guide to all this here:
http://www.cardomain.com/ride/749143/8
It's not that difficult as long as you have a good set of tools to do it with. If those axles haven't been apart for a while there's a good chance you'll be fighting to get the bolts off. And as someone else said above, the passenger side axle is a PITA if you dont have the proper tools.
Old Jan 18, 2006 | 02:21 PM
MaximaOverdo$e's Avatar
Orange Max Fully Loaded
Heres A pic of the illest max youll ever come across. Its been 3 years in the making but hard work pays off.
Old Jan 18, 2006 | 03:09 PM
internetautomar's Avatar
mod or sell?
WTF does that crappy picture have to do with winter??
Old Jan 18, 2006 | 04:07 PM
OBEEWON's Avatar
wow, so random...that beach looks nice.
Old Jan 18, 2006 | 05:06 PM
CyMax's Avatar
Or.... Just have to do it 3 times!! I think I could do it now in 1.5-2hrs MAX. Well there are the 3 manditory 5 min beer brakes so that might be tight. Again the key is having the tools. A good air compressor, impact wrench, air hammer torque wrench ect ect ect.
Old Jan 18, 2006 | 05:25 PM
and a strong breaker bar and a nice thick long pipe to go on the end of it... those axle nuts have close to 200 LBS of torque on them!
Old Feb 16, 2006 | 09:23 AM
T33MSlo's Avatar
lllllllllllllllllllllllll
T33MSlo's Avatar
lllllllllllllllllllllllllllllllllllll
Old Feb 16, 2006 | 10:04 AM
Michael's Avatar
Back in a 3rd Gen.
You should probably post actual info in threads to reach your 15 limit. you will be banned for doing what you have done here...if you dont believe it read the ban log.
TKHanson
Nov 24, 2018 01:39 AM
JRod28
Feb 4, 2016 11:07 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
Vequity
Sep 10, 2015 05:26 AM
