Why replace the PCV valve?
Old Jan 14, 2006 | 08:41 AM
hoyshnin's Avatar
Baby's on the Half Tip!
When I bought my 92 SE a few months ago, I took it into a Firestone for a buyer's inspection. They told me I needed the PCV valve changed. I've bought one and am still planning on paying someone to install it for me (because of the horrible location of course), but is it even necessary?
Do I really need to change my PCV valve? What does it affect? The car has 131,000 miles and runs like a champ. I baby it; run full synthetic, use premium gas, etc, but is the new PCV valve needed?
Thanks guys for your help, this is my first post btw!
Old Jan 14, 2006 | 09:44 AM
aminus21's Avatar
it is a maintenance part, that should be replaced every 30k miles. its not that hard to replace, all u need is a good set of plyers..beware though that the hose might break when u remove it..i would change the hose too..get it from a nissan dealer.
Old Jan 14, 2006 | 10:04 AM
CnR's 90 max's Avatar
Old Jan 14, 2006 | 12:33 PM
Josh's Avatar
i really would not have someone else do it for you, i mean if you cant find the 30 min tops to put it on then yeah have someone else do it but it really is very easy to do(easier still with the hood off).the hardest part is fitting the deep socket down there with those hose in the way.
Old Jan 14, 2006 | 02:04 PM
eric93SE's Avatar
The pcv valve can get gummed up with oil that can possibly bake on, which wouldn't allow it to function. Personally I've replaced mine like 2-3 times, I don't think it really needed though. You can clean out an old one with carb cleaner or soaking it in some cleaner to dissolve the oil.
The PCV is basically a one-way valve that allows hot fumes to leave the crankcase (combustion funes that have gotten past the piston seals and entered the crankcase). Fresh air enters the crankcase through the air stack (pcv breather) and helps carry out the hot gasses. So in a car that the pcv is stuck and not functioning properly will have hot gasses building up in the crankcase and this will breakdown the oil a lot sooner, also the breather helps remove moisture from the oil when the oil gets hot.
Some civics require that the pcv gets changed (I think) every 10 or 15K miles!
Old Jan 20, 2006 | 03:10 PM
sp3dymax's Avatar
u guys mind posting a pic of where its located so I can change it on my ride.
Old Jan 20, 2006 | 09:38 PM
hoyshnin's Avatar
do u have an se or gxe?
Old Jan 21, 2006 | 09:54 AM
Josh's Avatar
here it is for the SE (ve engine)
Old Jan 21, 2006 | 10:09 AM
SouthStar019's Avatar
u can only buy that hose from nissan?
Old Jan 21, 2006 | 01:38 PM
sp3dymax's Avatar
Sorry I Have a GXE a pic for that engine.
what is it agian? the VG30?
Old Jan 21, 2006 | 02:39 PM
Maxima Man's Avatar
You have the VG30 engine.
Great motor !!!
The PVC valve is located on the top right backside of the intake manifold it has a hose that goes from the vavle cover to the intake manifold. Hope this helps!!
Old Feb 18, 2006 | 02:22 PM
dadsmax's Avatar
cake work right on the intake 17mm wrench I think?
Old Feb 20, 2006 | 02:33 PM
hoyshnin's Avatar
What do you do with the hose, can you just pull that off? And any suggestions on the best tool to use to get the pcv valve off and a new one on? Will just a 17mm wrench fit down there and everything?
Old Feb 20, 2006 | 03:08 PM
Josh's Avatar
Just push the hose out of the way once you have it off, its a pain because it will keep coming back to cover the hole so you'll just have to work around it.
I just use a deep socket with an extension and that works fine, you will however need to start the threads on the new valve before you use the socket.
Old Feb 20, 2006 | 03:17 PM
92 Max's Avatar
PCV Removal on the SE
I found that a mirror, a universal joint for the ratchet and a pair of extra long needle nosed pliers ( one straight, the other angled, about 11 ") worked well in changing the PCV. First Spray the area with brake cleaner to get rid of the dirt and oil stuck around it to prevent this from falling into the engine. Then use the needle nosed to pull off the spring clamp on the rubber hose connector to the PCV. When I did this the hose slipped off with the clamp or use the pliers to gently twist the hose off (perhaps cover the tip with tape to prevent chewing up the hose). Then apply the deep socket to the valve with the universal attached ( the PCV comes out of the block at an angle, so straight in won't work). A mirror may help in seeing the PCV, about 10" below the Intake Plenum.
Old Feb 20, 2006 | 04:22 PM
Josh's Avatar
Brake cleaner is NOT the best thing to use in the presence of plastics and rubber, use engine cleaner or something like that.
Old Feb 20, 2006 | 05:19 PM
92 Max's Avatar
Clean PCV
Good Point. Read the label of what you use. If it's no good for rubber or plastic don't use it.
Old Feb 21, 2006 | 12:09 PM
DirtyErnie's Avatar
actaully, what happens when the PCV gets stuck is your blow-by and oil gasses go out the breather pipe and into the intake and scum up the MAF (if applicable) and cause all kinds of problems.
change the PCV if you start seeing oily scum in the intake tract or if the filter gets oily. definately cheaper than a MAF sensor.
Ern
CorollaULEV
30
Aug 9, 2021 08:11 PM
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
