Replacing Starter
Old Jan 18, 2006 | 03:10 PM
Mattster's Avatar
Replacing Starter
There is a 94 Maxima SE for sale up here for $750 that just needs a starter. How hard is it to replace the starter on the VE?
Old Jan 18, 2006 | 03:26 PM
internetautomar's Avatar
mod or sell?
easy shmeezy
check the AZ link in stickies for directions
Old Jan 18, 2006 | 04:08 PM
Drivin Maxima's Avatar
easy shmeezy
Yeah true that haha...but seriously though, real easy..........and 750 for a VE...not too shabby congrats on the find
Old Jan 18, 2006 | 04:44 PM
Mattster's Avatar
its an automatic but the interior is good. The exterior is has a few scuffs on the bumper and the front bumper is black instead of blue like the rest of the body but other than that is in good shape.
Old Jan 18, 2006 | 05:09 PM
DaWifey's90's Avatar
what can my max do for me
it's like 2 mounting bolts, one connector and a wire.
the most difficult part is getting the stupis splash shield outof your way - if u even have them on anymore
Old Jan 18, 2006 | 05:16 PM
maximapitko's Avatar
The Bulgarian Guy
automatic?starter is busted?No way to start it? Heh,be very careful if that's the case and do not believe the seller when he/she tells you that that's all it needs. Replacing a starter is super easy and takes less then 5 min after which you can get double the asking price...sounds fishy to me...
Old Jan 18, 2006 | 05:21 PM
vansskaterfreek's Avatar
be very careful man.......go out and get a starter for that car from autozone......install the new starter and try it out before you buy....... make sure it starts!!!!!! on my old VE motor.. the starter was actually fine.. but the motor was locked up!!!!!!!! be careful and do that man... and if the motor is bad......return the bought starter! i would recommend doign this just to make sure
the starter has two 14MM bolts that hold it in and a cable and a thin wire......it is mounted on top of the tranny so you dont have to remove the splash guards.. just lift the hood and look under the intake box thingy.. well it is next to it... and just remove the 2 bolts and reinstall the new one...
Old Jan 18, 2006 | 05:40 PM
Mattster's Avatar
Ill probably go look at it first and inspect it. That is if I deciede to get a Maxima again. I like my truck I traded my Max for. Updated my homepage thing when you click my name to go to pictures of it.
Old Jan 18, 2006 | 06:14 PM
try this man..you have NOTHING to loose.. if the motor is locked up.. just return itto the store.. and you get your money back!
Old Jan 18, 2006 | 11:21 PM
alextothestars's Avatar
exactly; the local pontiac dealer tried to sell me a 98 grand am with some serious lack of power...smelled like coolant...and there was coolant leaking after the drive (when they sent an associate to sit in with me...and i still floored it). they wanted 2800 or something...
they called back and told me that the leak was a head gasket and that they would deduct it from the price and i could fix it myself with my own money since they cut the price down....
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
