timing chain tensioner
I did the test talked about in the VTC TSB of the upper timing chain tensioners. I cranked the engine for several seconds after the upper chain covers were off and I found what I had suspected. The rear upper timing chain tensioner came out and stayed out. The front one flopped back and forth as the engine cranked (long enough for the oil light to go off.
I'm going to at least clean, and probably change this tensioner, but I can't find any info on whether there is a gasket or "o" ring for this front tensioner. Does anyone know? I want to make sure I'm ready to catch anything that may fall into the lower chain area when I disassemble it.
I have the Loud Clicking Noise at the rear (left) side of the engine and it appears to be the noise referred to in the VTC posts I've seen in this forum. Could this noise also result from the upper timing chain tensioner?
Assuming you have a VE, which you made no mention of...
sctludwig
09-01-2022 01:32 PM
kjlouis
10-03-2015 05:29 AM
trungg86
09-04-2015 04:58 AM
