How to Support Engine While Removing Oil Pan?
Old Feb 25, 2006 | 11:39 AM
maxitech's Avatar
As the title indicates, I am wondering how you go about supporting the engine while removing the oil pan. There is no ring to hang the engine from (at least on the VG) and I don't want to take any chances while I'm underneath the car. A little help, please?
Old Feb 25, 2006 | 11:45 AM
Greeny's Avatar
¯\(°_o)/¯
Old Feb 25, 2006 | 12:06 PM
Scope's Avatar
Im izz sexay
I was thinking the same thing.
Old Feb 25, 2006 | 12:40 PM
MrGone's Avatar
I'm assuming you don't have access to a hoist, and are trying to avoid buying one.
leave the transmission mounts alone and carefully support the pulley with a wood block.
Old Feb 25, 2006 | 12:59 PM
maxitech's Avatar
Hmm...OK I will do that when I get that far. Right now I've hit a snag...How do you get these damn cam seals out? I tried putting the bolt back in to pull the cam out, but it won't move. the FSM says to remove them. Some people said its not necessary to remove the cams, but there is no where to hook the seal puller on to. The crank sprocket doesn't really have much to grab onto and it's no wanting to move either. Help!
Old Feb 25, 2006 | 01:20 PM
MrGone's Avatar
I believe some people screw a screw into the seal and pull it out, but becareful not to scratch the journal. I've never done a timing belt on a VG so you'll probably want to wait for someone who has to chime in (Pervis Anathema, Matt, Dan, etc)
Old Feb 25, 2006 | 03:10 PM
vansskaterfreek's Avatar
i had to fab somehting up.. but i forgot what i did..LOL.. yeah, drill a screw into the seal, BUT DO NOT GO TOO DEEP!!!!! IF OYU HIT THE CAM< OR WHATEVER IS BACK THERE< YOU ARE IN DEEP SH*T!
Old Feb 25, 2006 | 03:16 PM
Pervis Anathema's Avatar
Nooo......!!!!!!!!!!!!!!!!!! My poor VG will never be the same. I gouged the freaking **** out my front cam with a screw. She leaks oil to this day. I highly recommend doing this the Dan way. (IIRC) Go to Sears, buy a pick set. Gingerly use the picks to get the seals out.
Yes, it is a biatch if you have never done it. Yes, it is time consuming and stressful. For the love of God, just don't use a screw.
Old Feb 25, 2006 | 04:23 PM
maxitech's Avatar
Yeah, I got a little bit of the cam, but took some permatex and repaired the little bit of damage, making it flush. But it's dinner time, so hopefully you guys can chime in with my next 2 issues while I eat.
1) One of the cam seals got pushed in a bit too deep on one side of it. Is this OK, or will I have to pull it, wait till Monday, and get another one?
2) That freakin' crank sprocket will not come off! I know the seal leaks, but I'm just about ready to say f##k it and forget about it. How the hell can I get it off w/o turning the crank at all? I heated it up and tried to pull it, but no luck.
Oh yeah, one other thing...I broke some cooling system sensor earlier. I will post pics of it later so I can figure out what it is. C'mon guys, I want to put this thing back together!!!
Old Feb 25, 2006 | 04:33 PM
Not sure. One of mine is pushed pretty far back but that is the cam that I scratched. I don't know if the seal being that far back contributes to the leak or not.
Mine was a BITCH to get off. Took hours. I tried prying it off with a screwdriver, heating it... I finally ended up drilling holes in it and taking a steering wheel puller to it. I got a new sprocket from the local dealer for ~$35. You need to change this seal. Just watch out don't score the crankshaft.
It is probably the sender for you temperature gauge. Small little connector?
Old Feb 25, 2006 | 04:35 PM
Michael's Avatar
Back in a 3rd Gen.
1. not sure
2. I had the same problem with my last GXE. What I did was drill a hole on the sprocket on each side of the crank, tapped them with the correct tap for some long bolts I had, used a steering wheel puller to pull it out. Sounds time consuming but it took me all of an hour maybe to do that where I worked for several hours trying to get that sucker out before.
Now that I have a stud welder the next time I have a problem like that I will probably just weld a couple of studs on there and see if I can pull it with the slide hammer lol...not sure if that will work but worth a try.
EDIT: dangit PA beat me to it.
Old Feb 25, 2006 | 07:19 PM
SurraTT's Avatar
HR Swap Pioneer
thats what i done
Old May 8, 2006 | 04:30 PM
maxitech's Avatar
Bringing back this old thread to the origin of its title...Where can you attach a hook to a VG motor? I now have access to a hoist with a hook rigged on a pulley system directly over it. Only problem is, I don't see a place to hook the motor!
Old May 8, 2006 | 04:38 PM
SurraTT's Avatar
HR Swap Pioneer
u can use the exhaust manifolds, also there is a little loop wehre the ground from the battry it
Old May 8, 2006 | 04:40 PM
Greeny's Avatar
¯\(°_o)/¯
Get a chain dude...
Old May 8, 2006 | 04:44 PM
MrGone's Avatar
Originally Posted by MyGreenMax94
Get a chain dude...
what he said
twice
times two
Old May 8, 2006 | 04:46 PM
maxitech's Avatar
Sorry, didn't catch that last part...And I need to suspend it so I can replace the oil pan and EXHAUST MANIFOLD STUDS!
And, Green Max, are you suggesting I wrap a chain around the engine?
Is there a hook point on VEs?
Old May 8, 2006 | 04:57 PM
MrGone's Avatar
toss a chain around the manifolds and hoist it that way
do the oil pan work, "reinstall" the engine and do the manifolds (or do the manifolds first)
I've never had to pull a VG before so I'm not sure of any other bolt holes. For the VE the first couple I was somewhat hesitant with using the manifolds but it works great (easier to balance, sturdy, etc)
Old May 8, 2006 | 05:08 PM
maxitech's Avatar
Wow, what a pain in the ***...
Old May 8, 2006 | 07:03 PM
on the VG, i hooked an old seat belt to the upper intake manifold, and it held perfectly......on the VE, i used the exhaust studs.... but you can use the a/c bracket and part of the upper intake manifold also.......you may wanna put a second strap on it for stablility, and for rocking the motor back and forth......
Old May 8, 2006 | 07:57 PM
Alex_V
I used my ac comp mounting plate. Its really beefy. Ive pulled 2 VG's out that way. works good.
~Alex
Old May 8, 2006 | 08:03 PM
Matt93SE's Avatar
STFU n00b!
now that's some ghetto ****!
Old May 9, 2006 | 04:58 AM
Greeny's Avatar
¯\(°_o)/¯
It's redneck $hit also,most of the junkyards around here use seat belts to remove all their engines...V8's included...
Old May 9, 2006 | 08:04 AM
maxitech's Avatar
You wanna see redneck? Here's a pic of my buddy's stock car being pushed into the building with the hoist I will be using!
And yes, that building is made out of OSB!
Old May 9, 2006 | 07:10 PM
****, that seat belt is strong as hell...... i used it from the junk yard.. they hooked it up and they gavew me the FRE seat belt... so i use that to pull all my engines..... also with trannies hooked to it also...... that seat belt is so strong, it lifted the whole front end of my car up!!!!
Old May 10, 2006 | 06:50 AM
Matt93SE's Avatar
STFU n00b!
it may work, but it's still ghetto.
but yes, I'm very familiar with the seatbelt-as-a-sling thing. I've gotten my share of engines from junkyards and almost all of them have been hoisted there using seatbelts.
when they get to my house, they get chains though.
Old May 10, 2006 | 07:16 AM
Greeny's Avatar
¯\(°_o)/¯
Me too,the seat belt thing just doesn't sit well with me..
Old May 10, 2006 | 02:12 PM
Jeff92se's Avatar
I'm needing a caw
I prefer this:
BTW. Never use screwdrivers to remove seals. Just to buy a cheap seal puller.
Old May 10, 2006 | 06:02 PM
maxitech's Avatar
Did you just wrap the chain arond the engine, Jeff? Because that looks similar to the apparratus I will be using.
Old May 10, 2006 | 06:12 PM
Greeny's Avatar
¯\(°_o)/¯
Just wrap the chains around the front and rear manifolds...
Old May 10, 2006 | 06:22 PM
but what will happen when you have more than one broken exhaust stud????
Old May 10, 2006 | 06:34 PM
Greeny's Avatar
¯\(°_o)/¯
Worry warts!!!!
They will hold just fine even with a few broke studs..
Old May 10, 2006 | 06:42 PM
ok, ive hever had any broken studs, so i didnt know....... ohh BTW that is a big *** pic of a dam smiley
PH98I30
Jan 9, 2025 08:08 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
kmitchel
Oct 30, 2015 10:12 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
