Back on the Road
Old Feb 28, 2006 | 07:07 PM
maxitech's Avatar
Back on the Road
After a 4 day off and on project, I replaced the cam seals, water pump, timing belt, and installed an Unorthodox Racing UDP. The car seems to wind up a bit quicker, which is kinda sweet!
Only one problem. After getting a little too excited when I was wrenching on a bolt I broke the coolant temp sensor. The heat in the car took awhile to warm up and then after blowing for awhile more it turned back cold! Whadya think? Faulty sensor? Bad connection? I wont have time to play around with it for a couple of days.
Old Feb 28, 2006 | 07:14 PM
Michael's Avatar
Back in a 3rd Gen.
air in the system. Follow the procedure to remove it and it should take care of it.
Old Mar 1, 2006 | 11:25 PM
VEvolution's Avatar
I miss my VE
How was the UDP to get on? I'll have to be doing it myself soon enough, and I read many had ran into some trouble.
Old Mar 2, 2006 | 07:10 AM
maxitech's Avatar
If you are not going any further than the UDP it shouldn't be too bad. But you will find an inpact wrench useful in removing the pulley bolt. If you don't have one, have someone hold the pulley in place with a belt, get an impact socket (27mm) and hit the ratchet with a hammer.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
