Putting the Injecter into the rail.
Old Mar 2, 2006 | 05:51 PM
heresmymind
Is there a specific way to do this so i dont mess up the o rings cause i hope i dont have to take apart my engine again... (3rd time). Can i just place it in as fas as it goes and tighten the screws evenly or should i push damn hard?
Old Mar 2, 2006 | 06:10 PM
Greeny's Avatar
¯\(°_o)/¯
Vasoline is your friend..
Old Mar 2, 2006 | 08:42 PM
backNblackj30
ky jelly and a condom!
Old Mar 2, 2006 | 09:29 PM
heresmymind
i asked how to put a fuel injecter into a fuel rail. not for sexual advice. i am deff well educated in that.:-p its cars i'm still learning!
Old Mar 3, 2006 | 06:55 AM
TeacherKP's Avatar
Put the smaller o-ring in the groove in the injector housing and then press the injector (with the larger top o-ring) into the housing using hand pressure. Once you have pressed it in far enough for the screws on the cap to catch, tighten the screws evenly until they are tight. The FSV calls for only gasoline as a lube, but I used WD-40.
I would suggest attaching the fuel lines to the rail before installing the rail and turning the switch on to pressurize the rail to verify that nothing is leaking.
Old Mar 3, 2006 | 07:07 AM
mtcookson's Avatar
I tried using the screws in the cap to put mine in and ended up with this:
After that mess i just layed the cap on top of the injector and lightly tapped the cap wth a hammer until the injector was fully seated. Worked like a charm.
Old Mar 3, 2006 | 08:05 AM
Jeff92se's Avatar
I'm needing a caw
I found instructions on how to properly install the injectors in about 20 sec in the STICKIES.
Old Mar 3, 2006 | 08:12 AM
wawa92gxe's Avatar
Take the fuel rail out. Lube the o-rings with a smear of engine oil, then carefully insert the injector into the rail horizontally, and hand tighten it down while turning. May need a little effort, but not too hard. When the big o-ring seats, you can put the cap on and hand tighten the screws evently. Reconnect the fuel line, pressurize the system and check leaking. Then put everything back on. Including my friends' VG, i have done this, for god's sake, 8 times without any problems.
Old Mar 4, 2006 | 10:50 AM
92 Max's Avatar
One suggestion. Don't use silicone based lubricants, only petroleum based. The silicone won't dissolve in gasoline and will migrate and clog the injectors.
James92SE
142
Jan 2, 2024 09:23 AM
220k+ A32
Sep 23, 2015 03:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
Justin Kroll
Sep 2, 2015 11:06 AM
