Anyone have any ideas?
Old Mar 9, 2006 | 01:50 PM
Travis92se's Avatar
I was in the process of doing a compression check and I was unable to get a good seal to for the gauge. The extention hose wasn't stiff enough to tighten the spark plug adapter so I tried to use a socket to tighten it which seemed to work. It uses a 3/4" socket which is a tight fit but I got it in there and tightened up the adapter. Great right? Well when I went to pull out the socket it won't come out. Stuck, @#$%, @#$#, @#$$, @#$$. After an hour of wrestling with it I still can't get it out of the head. Apparently it was tighter that I thought.
Am I screwed or is there anything that I can try? Do you think I could heat the socket and have a better chance of getting it out? Any other ideas appreciated.
Old Mar 9, 2006 | 01:51 PM
MrSector9's Avatar
heating the socket would make it harder to get out as it would expand slightly... you owudl want to heat the alumnum where it is a tight fit and possibly drop some ice down onto the socket.
Old Mar 9, 2006 | 02:02 PM
Travis92se's Avatar
Ok, then that is probably what happened. The head probably heated the socket and made it expand. I was pissed and wasn't thinking about that. Let's go find out.
Old Mar 9, 2006 | 03:39 PM
VEvolution's Avatar
I miss my VE
What have you tried so far to get it out?
Old Mar 9, 2006 | 06:21 PM
Travis92se's Avatar
I let everything cool down completely and sprayed some liquid wrench around it. I can tell that it is not as tight. I can twist it with the wrench but it doesn't move in or out just around. I can push the socket extention to the side to get a little pull but still no luck. It is a deep well socket with about 1/4 - 1/8 of the socket sticking out but I haven't been able to get it to move out anymore. ???? Any ideas?
Old Mar 9, 2006 | 06:39 PM
VEvolution's Avatar
I miss my VE
Do you think you could maybe clamp on as tight as possible with some vice grips on that small part stickin out? Pull it out like that maybe? A clear pic would really help us all out alot.
Old Mar 9, 2006 | 06:44 PM
Travis92se's Avatar
I'll take a look at it tomorrow. Probably have to go ahead and get the valve cover out of the way and see if I can make some room. I'll get a pic after that.
Old Mar 9, 2006 | 07:51 PM
VEvolution's Avatar
I miss my VE
I would just snap a good pic of it first before doing anything else. Im sure someone including me can help out alot better if we actually saw the situation.
Old Mar 9, 2006 | 08:12 PM
MrSector9's Avatar
maybe modify a screw driver so the end is a 90degree angle... give you a good pulling power compared to the extension.. IF you cant hook some needle nose VG's on it.
===---' < liike that rad ascii screwdriver yo
Old Mar 10, 2006 | 08:05 PM
Travis92se's Avatar
Well, here is what I am working with. I haven't had any luck with anything I have tried.
Any ideas besides just removing the head?
Old Mar 10, 2006 | 08:15 PM
MrSector9's Avatar
Umm I dont know fi you tried this.. but try it
Take some ice and set it on the socket... like in the square part so that you try not to touch the aluminum of the head iwht it... then take a propane torch adn apply ALOT of FAST heat to the outside of the "circle" in where the oil touches it... this will expand that pieces and hopefuly the ice will keep the socket cool. as thta is how it got in there :P warm aluminum head with a cool steel socket.
Old Mar 11, 2006 | 01:08 AM
VEvolution's Avatar
I miss my VE
Wow, that thing looks lost in there. Yeah you can try what MrSector9 said, but you'll need a tool to pull it out afterwords. Do you have 0 clearance underneath that socket? Can you not get anything underneath it to maybe hook it, play around with it, and pull it up? I think your just missing the right tool for this.
Old Mar 11, 2006 | 01:55 AM
Greeny's Avatar
¯\(°_o)/¯
If you get real desperate,j/b weld your extension in the end of the socket...
Old Mar 11, 2006 | 03:10 AM
Greeny's Avatar
¯\(°_o)/¯
Or you can buy a one of these...
Old Mar 11, 2006 | 03:20 AM
Greeny's Avatar
¯\(°_o)/¯
Or i could swing by with teh welder and weld the extension on
Old Mar 11, 2006 | 05:36 PM
Dysfunctional
uhhh
put some JB weld on the extension and weld the extension on the socket , u just have to through the 2 out when ur done, or have a permenet socket / extension
Old Mar 11, 2006 | 05:45 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Dysfunctional
uhhh
http://forums.maxima.org/showpost.ph...7&postcount=13
Old Mar 11, 2006 | 07:05 PM
JRS89MAX's Avatar
Try an extension and tap side to side with a hammer if you got room.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
