So how do i make my antenna stay down for good.
Old Mar 9, 2006 | 02:43 PM
2k3TitaniumSe's Avatar
It broke years ago and thought it would look good as a "shorty" antenna but now I'm sick of it. Anyone know how to put it down?
Old Mar 9, 2006 | 02:56 PM
internetautomar's Avatar
mod or sell?
BFH!!!
I'll assume you've tryed to push it down by hand
Old Mar 9, 2006 | 03:30 PM
VEvolution's Avatar
I miss my VE
Could it be that cool antenna mast?
Old Mar 9, 2006 | 04:08 PM
ColombianMax's Avatar
Stop by the house, we'll drive to Brian's together and the 3 of us will figure it out then we'll play chess on top of the hood. Problem solved.
You know my antenna works but its broken in half
Old Mar 9, 2006 | 04:33 PM
Josh's Avatar
push it down by hand then unplug it.
Old Mar 9, 2006 | 06:04 PM
CamryKilla's Avatar
i used a hammer....
Old Mar 9, 2006 | 08:11 PM
mod or sell?
if the motor itself is good just pick up a replacement mast.
Did that on the camry I had.
I lucked out on this max, the antenna works
Old Mar 9, 2006 | 09:42 PM
heresmymind
take the antena power lead from the stereo head unit and cut the wire. depending on what stereo u use. the wire is a diff color. keeping it plugged in through the actual antenna plug will keep it as the antenna but the power (amp turn on) wire that goes to the antena will rpevent it from going up n down if its cutt. i am drunk and cant read this propewr y so if there are tpes or anything feel fee to PM me.
Old Mar 9, 2006 | 10:57 PM
Josh's Avatar
You are drunk . Don't cut any wires just go back to where the jack is and feel around you see a wire for the motor, I think it had a blue sheeth, and unplug that at its connector.
Old Mar 10, 2006 | 04:41 PM
Well the motor is dead and I don't need the antenna to go up/down. I have an AF receiver.
Old Mar 10, 2006 | 07:10 PM
kcidmil's Avatar
Wish I had a welder right now, cause I would shave mine off.
Old Mar 10, 2006 | 08:03 PM
alextothestars's Avatar
if the motor is bad and you pushed it down, you might have damaged the antenna itself since you forced it down against the motors will. probably need to replace the motor, if that will even work, and disconnect the antenna wire from your radio so that the motor wont get power when the am/fm part is on (am/fm on raises the antenna; off lowers)
i have mine disconnected for good, as well. the antenna looks a bit stupid, in my own opinion.
Old Mar 11, 2006 | 08:39 AM
Well it's stuck and doesn't budge. I even tried the hammer to put it down. hmmm.....
Old Mar 11, 2006 | 08:54 AM
goon9's Avatar
Could use fiberglass.
Old Mar 11, 2006 | 01:52 PM
PovCityHustla's Avatar
What i done was, as soon as i turned off ma source unit, run out and push the antenna down, when i do that it when down mechanically with troubles but it went down. I disconnected the antenna turn on wire and left teh antenna plugged in. Now i still get crystal clear radio recpetion and the ungly antenna stays down
Old Mar 11, 2006 | 04:33 PM
92 Max's Avatar
crummy antennas
I just unpluged the power antenna and took it out. I soldered on a standard auto antenna jack and bought a manual antenna from Metra. It's black and looks fine on the car and only cost me $15.
Old Mar 11, 2006 | 04:43 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
well take it out and put in a bmw antenna in dosent have a mast and is powered by the power antenna on your rear window youll need the ESG module the black box and the antenna wire
Old Mar 12, 2006 | 07:31 AM
vansskaterfreek's Avatar
is that the stock antenna????? if it is, take the antenna motor out of the car, push antenna down and reinstall motor
DJLAX152
May 4, 2021 11:46 AM
Maxima30
Sep 7, 2015 06:13 PM
