replacing antenna mast....
Old Mar 27, 2006 | 04:50 PM
slickblack94's Avatar
Would anyone happen to have a stickie or link
on changing the mast ? I've searched and tried
to find a thread but no luck. thanx for any info.
94 se
Old Mar 27, 2006 | 05:01 PM
Greeny's Avatar
¯\(°_o)/¯
Buy this...
Edit: ebay item sold..
Old Mar 27, 2006 | 05:11 PM
sublunary's Avatar
Originally Posted by MyGreenMax94
man, youre really helpful. i don't post much but i read alot of threads and you are always coming through with pictures, diagrams and stuff like this. good looking out
Old Mar 27, 2006 | 05:19 PM
Greeny's Avatar
¯\(°_o)/¯
Old Mar 27, 2006 | 05:21 PM
I just bought the antenna not the motor.I was looking for
directions to install.
Old Mar 27, 2006 | 05:28 PM
Greeny's Avatar
¯\(°_o)/¯
http://gen3.4mg.com/
Click on library on the left side of the page,and then go to antenna mast replacement....
Old Mar 28, 2006 | 05:31 AM
es_amixam's Avatar
Here's another how-to, from the 4dsc.com site: http://www.4dsc.com/articles/exterio..._antenna.shtml
One thing to keep in mind is that the needle-nose pliers it says to use for loosening the nut may not work, which is what happened in my case. Vice grips over a rag may work better.
Old Mar 28, 2006 | 08:11 AM
internetautomar's Avatar
mod or sell?
on the last car I did a mast replacement on, I had to pull the assembly out and manually wind some of the teeth on the bench and power it there.
no fun at all.
at least I had the antenna nut tool
Old Mar 28, 2006 | 11:23 AM
bluemax89's Avatar
I've replaced just the antenna mast. Here's basically what I did - power ON the radio, as the antenna approached maximum extension, pull the antenna up and out of the shaft (it may take a little force).
Remember which direction the teeth were facing.
Move the collar that holds the antenna in place from the old antenna to the new one.
Insert the new antenna into the shaft as far as it will go and have someone turn the radio OFF. The new antenna mast should feed right in.
Hope this helps...
Old Mar 29, 2006 | 03:04 PM
thanks guys...I had to pull the antenna motor to get
the piece that broke inside it. took about 1.5 hours
and a six of budlight,but it was well worth it when
the antenna went down flush.... d.w.
Old Apr 28, 2006 | 10:18 AM
planetnebur's Avatar
Good Info
Thanks for the thread, just what the dr. ordered.
Old May 17, 2006 | 08:33 AM
dyme's Avatar
Wish I would have seen this thread a few weeks back. The internal plastic zip cord on mine broke, and I wasn't sure about the top-collar/inner thread mechanism at base of mast. Nice post !!
Old Aug 20, 2006 | 06:24 AM
jorgeg73's Avatar
very nice information thanks
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
