wierd problem....
Old Apr 21, 2006 | 01:10 PM
fred's Avatar
wierd problem....
ok i have the gxe with the touch pad entry. it works fine. i can roll the windows down using the touchpad, but i cant roll the window down from inside the car, with the normal switch or the one touch switch. however, i can roll the window up from inside the car. is this caused by a bad 'master' switch(the one that can control all the windows)? or something different, like a gremlin inside my door that only blocks that? btw, i can roll down both passensger side windows using the 'master' switches, but the driver rear wont go down with it. but i can hear it trying to go up when you go in that direction. so is it possible for the switches to only fail in one direction?
Old Apr 21, 2006 | 01:12 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the master switch to me....
Old Apr 21, 2006 | 01:30 PM
Hectic's Avatar
hehe, i actually just got done working on the master switch pcb of my black car about 20 minutes ago. actually it's not my car anymore, it will be in the hands of its new owner tomorrow. but i said i would fix the window as a courtesy before i deliver the car. i had the same exact same problem except no touch pad here. after taking the switch box apart and examining the pcb, i discovered a couple faint burns, on one of the traces, shaved off some laquer on both sides and bridged a wire across and all's good. i should have taken a pic before reinstalling it to show you where the gap was. it's always nice to fix instead of buying new parts. all of the switches worked except for driver window down and auto down. up worked and all other switches worked. see if you can't fix it before buying another one.
Old Apr 21, 2006 | 02:06 PM
JstAntrRoky's Avatar
Hectic that is awesome, I will have to try that this weekend. I only have control over the driver window.
Old Apr 21, 2006 | 02:17 PM
Greeny's Avatar
¯\(°_o)/¯
Or you could just do this..
http://cgi.ebay.com/ebaymotors/1992-...spagenameZWDVW
Old Apr 22, 2006 | 12:08 AM
Hectic's Avatar
Originally Posted by MyGreenMax94
why? the auction ends in 4 days, the weekend is here, free fix + faster = better. that said, i was keeping an eye on that auction. i also called a local import junk yard and was quoted $65
Old Apr 22, 2006 | 03:43 AM
Greeny's Avatar
¯\(°_o)/¯
just a thought.....
Old Apr 22, 2006 | 06:25 AM
Hectic's Avatar
heheh, aww, i'm sorry i just think it's worth a shot at fixing.
Old Apr 22, 2006 | 07:38 AM
Greeny's Avatar
¯\(°_o)/¯
Hehe j/k
Old Apr 22, 2006 | 01:39 PM
fred's Avatar
ok i will have to take a look at that. thanks
Old May 17, 2006 | 08:41 AM
dyme's Avatar
nice hack - may try this as well once all window regulators are re-connected and working. touchpad works occasionally - but not always. ??
Lakersallday24
Jun 16, 2019 01:35 AM
MaDMaX024
Nov 3, 2001 11:02 AM
BriGuyMax
Oct 30, 2001 07:19 PM
mykizism
Sep 13, 2001 05:29 AM
95pbGXE
Sep 5, 2001 07:15 PM
