rewiring problem
Old Jun 15, 2001 | 06:44 PM
fnkmaster's Avatar
i was trying to rewire my blinkers... and i cut the black wire from the side marker which i think was the ground and connected it to the +ve (green wire) of the turn signal... unfortunately this did not work. and now my blinkers dont work at all... i suspect a blown fuse, even though the side marker lights up when the headlights are turned on. but no turn signals... ideas anyone?
Old Jun 16, 2001 | 06:09 PM
dnas420's Avatar
ok well
here is what i think you did. i bet you just opened the wire and wrapped it into it right? well you have to actually cut the black wire in half, run a wire from the pink on the front blinker to the black wire coming from the bulb of the corner part, and just tape the other half of the black wire off so it doesnt touch anything else. Your blinkers dont work becuase you are shorting them out by just merging a signal into a ground. try this and tell if it fixes it. good luck
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
