Where can i find?
Old Apr 28, 2006 | 07:44 PM
xx-Marshall-xx's Avatar
kthxbye2u
Where can i find?
Where do you all find these new motors?... i see some on EBAY.. im iffy about buying those especially from japan?... like i saw a while back $600 for a NEW VE30DE im like KEWL but ebay.. and only $600?... brand new yeahright
Old Apr 28, 2006 | 08:00 PM
Matt93SE's Avatar
STFU n00b!
it's definitely not new. price on a new one from nissan is about $6500.
Old Apr 28, 2006 | 08:05 PM
belakithom's Avatar
True, they're probably refurbished and/or remanufactured.
Old Apr 28, 2006 | 08:35 PM
Alex_V
no they are engines with low miles pulled from jap cars. They are fined if an engine gets over a certian amount of miles. Most buy new engines and sell the old ones, and those are the ones we get.
~Alex
Old Apr 29, 2006 | 06:15 AM
kthxbye2u
ohhh... kool ok ill prob still get a new max... i just was curious for a long time about that
thanks
Old Apr 29, 2006 | 07:58 AM
hoyshnin's Avatar
Baby's on the Half Tip!
Yeah most of the ebay max engines say they have between 40,000-60,000 miles on them.
Old Apr 29, 2006 | 03:27 PM
Chris Gregg's Avatar
Get Off My Lawn
Beware JDM engines! Do NOT buy from Midwest Engines!
Old Apr 29, 2006 | 07:18 PM
internetautomar's Avatar
mod or sell?
JDM motors allegedly have low miles on them, but when you consider that any VE is at least 12 years old, the chances of one just now making it into the yard with only 30-60k is pretty low.
I'd rather take my chances on a motor from a local wrecker that is still in the car and I can hear it run along with check the compression etc...
Old Apr 30, 2006 | 08:25 AM
Matt93SE's Avatar
STFU n00b!
those "low mileage JDM motors" ARE NOT LOW MILEAGE!!!! the rumors about them only having 30-40k are all bull****. I've swapped several of these that customers have brought me, and I see the timing belt replacement stickers still on them (for the VGs), and one of them was showing a 200,000km replacement date of around 2002.. so it's likely that engine had well over that!! And for those of you that can't do the math, 200,000km is around 120,000 miles.
Old May 1, 2006 | 02:06 PM
kthxbye2u
ok then... what do you basically do when you rebuild an engine?...... if you dont want to answer you dont have to ill ask my real life friend but im just wondering and is it a lot to do... ?
Old May 1, 2006 | 03:08 PM
Matt93SE's Avatar
STFU n00b!
It depends on what all is wrong.
If it's just high mileage and losing power, then you can pull the pistons out, hone the cylinders, replace the piston rings, send the heads to a machine shop and have them rebuilt (new valve stem seals, check valve guides, grind valves as needed, etc), and replace the bearings in the bottom end of the block.
I would also recommend rebuilding the VTC assemblies (about $60 in parts), and replacing the timing chain tensioners. Tehy're around $55 each and you need 3 of them. check all ghain guides too and replace as necessary. they run $10-35 each and you have about 8.
gaskets will cost you around $400, bearings will be $1-200, piston rings will be about $150, valve job will be about $250, and then you'll need to add up everything on the timing chains depending on what you want to replace.
Also don't forget to replace water pump, thermostat, front and rear main seals, transmission seals, etc. (which is all stuff you'd replace when buying a used engine as well.)
Old May 2, 2006 | 06:27 PM
rod_atl's Avatar
~Alex
NOT TRUE, the rason because they sell low mileage engines is because teir harsh environment, they are surrounded by ocean and typhoons and all sort of crappy weather. bottom line, when the car (chassis and body) are ready for the junkyard because of rust, the engine is still low miles. (explained to me by my local engine importer)
Old May 3, 2006 | 03:19 PM
kthxbye2u
thanks matt.. ill copy and paste that in a notepad ill use it in a later time lol sweet thanks
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
pears
Sep 18, 2015 05:25 AM
Vistance
Sep 17, 2015 05:17 AM
adamgalazka
Sep 8, 2015 01:27 PM
