Door Attach Thingies
Old May 2, 2006 | 08:38 PM
MorrisonMax's Avatar
O.K., I do not know the correct name for these, but they are the fasteners that attach the door panel to the metal part of the door. They are little plastic inserts and two are blue (the two on the upper left corner). Well, my key broke off in my driver's side door and I wanted to pull the door panel away to get a better look. I followed Craig Brace's instructions (these are very good and detailed I might add!) on this and all went well until I pulled the door panel off. The plastic end on the blue ones broke and I had to put a white one in it's place, but it does not look quite right.
Anyone know where I could get these, or what they are called so I know what to ask for. They can't be more then a few bucks for a set I would think.
Thanks.
Old May 3, 2006 | 05:59 AM
bhunter's Avatar
Boneyard or Dealer. You might take one with you and look at Advance Auto or Autozone. They have some assortments of little clips and something might be close enough to work.
Old May 3, 2006 | 06:46 AM
zhusst's Avatar
Door Panel Clips?
Old May 3, 2006 | 06:56 AM
internetautomar's Avatar
mod or sell?
Originally Posted by zhusst
Door Panel Clips?
yup, I just have a few holding my panel on. No ill affects
Old May 3, 2006 | 06:58 AM
Greeny's Avatar
¯\(°_o)/¯
I think i have some extras somewhere...I can mail them to ya if i can find them..
Old May 3, 2006 | 08:55 AM
92 Max's Avatar
Napa has a catalogue of these plastic fasteners. Take the old ones in there and match them up.
Old May 4, 2006 | 10:48 AM
Thanks all for your help. I went to Napa and the closest they have do not fit correctly (see below). MyGreenMax94, could you let me know if you find some extra you may have I need two blues and a few whites (see below). Thanks guys.
I am waiting to wash and clean my car until all work is done!!
Old May 9, 2006 | 09:40 AM
Any luck finding those MyGreenMax94?
Old May 9, 2006 | 09:51 AM
Greeny's Avatar
¯\(°_o)/¯
Sorry,all of them were broke..
Old May 9, 2006 | 01:19 PM
MrSector9's Avatar
why dont you just get them at the dealer?
www.courtesyparts.com for online dealer.
Old May 9, 2006 | 05:43 PM
I try to avoid going to the dealer if a fellow Maxima enthusiast had some extra, but now it looks like the dealer it is!
Old May 9, 2006 | 05:54 PM
Sgibb's Avatar
From this pic it looks like the top part of the panel isnt sitting in the top right.
Old May 9, 2006 | 09:48 PM
You're right! This was also something I was going to ask. Even if the door panel clips are installed, the top part still seems to not be sitting right. Any suggestions as to what is wrong?
Old May 10, 2006 | 05:53 AM
MrSector9's Avatar
the top has to slide down behind the door steel (by the window) kionda hard to explain.
The top fo the door panel wraps around the steel door at the top.
Put your window down and it is alot easier to get into place.
Old May 10, 2006 | 06:57 PM
Thanks for the explanation! All fixed, I did not realize the lip of the panel had to go over the door. All makes sense now and the new panel clips from Napa work! Thanks again!!!
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
