PCV Inline Filter
Old May 18, 2006 | 06:06 PM
-shock211-'s Avatar
PCV Inline Filter
Any VE guys add this to their engine?
Any problems like odd idling issues I've read about with 4th and 5th gen members?
Old May 18, 2006 | 06:22 PM
Greeny's Avatar
¯\(°_o)/¯
I thought about doing this to keep the oil from running down into my filter....
It might look though..
My ve already idles kinda crappy anyway so meh...
Old May 19, 2006 | 11:06 PM
Maxmus_X's Avatar
SHIFT_PANTS
I was thinking of doing it myself, it's only 15 and if it doesn't work all well...
Old May 20, 2006 | 06:39 AM
SurraTT's Avatar
HR Swap Pioneer
i also was thinking of doing this
i will try it out in a few weeks or so, it makes sence how it works i hope it will help
Old May 20, 2006 | 07:15 AM
Scope's Avatar
Im izz sexay
I wish I had pics of how mine was for my probe. There was litterally about 6 or 7 bottle caps full of oil in my TB boot next to my TB. My tb had oil residue everywhere. I put in a filter cleaned it out real good and the reset my idle (Disconnect the negative terminal of the battery and press your brakes afterwards. Wait 30 minutes then hook the battery back up) Once I did the idle relearn it idled rough for about 10 minutes then it ran perfectly fine if not better. I felt better since oil isn't going into my engine the way it was not intended to go in it.
Old May 21, 2006 | 04:28 AM
-shock211-'s Avatar
so everyone is like me? thinking about doing it.
Old May 21, 2006 | 05:51 AM
disgruntled's Avatar
http://forums.maxima.org/showthread.php?t=424959
Not on sale though, I have to perfect my welding skill first (whenever that is)
Old May 21, 2006 | 10:55 AM
VEvolution's Avatar
I miss my VE
You guys wouldn't happen to be talkin about the 'oil catch can' that I see on Supras all the time, would ya?
Old May 21, 2006 | 12:44 PM
SurraTT's Avatar
HR Swap Pioneer
i plan on doing this very soon, im gonna use the home depot thing though seems like its better than the can things, they are used for air compresser lines to get the water out so it dosent mess up the tools
Old May 28, 2006 | 04:22 PM
SurraTT's Avatar
HR Swap Pioneer
well i done it today, havent had it on for long ehough to catch oil, i had some clear hose that crushed under pressure, so i went to advance and got some fuel line, i still think i need some better hose
Old May 28, 2006 | 09:37 PM
maxitech's Avatar
Anyone rig one up for a VG out there?
Old May 29, 2006 | 03:11 AM
read my post man, and click on the link
Old May 29, 2006 | 10:45 AM
SurraTT's Avatar
HR Swap Pioneer
i got the braided hose today, it is a lot better, im eventually gonna cover it up with some black wireloom, i drove like 5 miles yesterday and had a noticble amount of oil in there.
im about to drive 50 miles or so and ill take a pic of the aftermath
Old May 30, 2006 | 04:40 PM
SurraTT's Avatar
HR Swap Pioneer
one question
when the car is running the oil in the bowl should be moving as i can tell air is going through it??
for some reason there is oil in both hoses, i think its from not having a clamp on the filter so today i put 2 on, i also turned the filter around and ran the car, there was nothign moving in the filter so i guess air wasent passing through it
im also thinking of adding a 2ed filter to the intake tube crankcase hose, whould this also catch a lot of oil?? i have seen them in both places but not at the same time
Old May 30, 2006 | 06:12 PM
eric93SE's Avatar
Something tells me that that's not such a good idea. Are you sure that inline filter is mean to filter out oil? Chances are thats going to impede the air flow for the hot blow-by gasses.
I would go with a catch can instead.
On my max, I ran a hose that bypasses that short metal section right after the pcv valve, so it runs straight from the pcv valve to the intake elbow on the manifold. But adding a sump would be a good idea.
Old May 30, 2006 | 11:06 PM
LvR's Avatar
LvR
I don't know at all what the exact inner construction and design of the filter unit is, but this is a typical "gravity filter" - IE - you somehow impede the airflow containing the oil vapor in the hose coming from the engine and typically would run it through a kind of "strainer" to allow the oil droplets to collect on that and drop down into the sight-glass section of the unit - you do not actually want any airflow through the sight-glass section as it would be defeating the object and once again vaporizing the already collected oil and transferring it further down the line to the inlet manifold - and you definitely do want the sight-glass to be under the level of the hoses running to/from it.
Question:
We do not yet have emission tests to pass on a frequent basis here in South Africa - but if my logic is right you will be having severe issues trying to pass those emission laws in your patch on Earth if you are able to already collect a significant amount of oil by just driving 5 miles - no?
Old May 31, 2006 | 02:25 PM
eric93SE's Avatar
He might have a lot of cylinder blow-by (worn piston rings).
My max doesn't use any oil after 3k+ miles.
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
