Axle or bearing issue??
Old May 18, 2006 | 07:15 PM
goon9's Avatar
Over the past couple years both axles were changed out. Now I have this sort of rapid bumping feeling on the passenger side on hard corners(slow and fast anything at all aggresive.). And when comming to a stop most of the time there's a brushing kind of sound. Can a bad bearing cause a thumping feeling?
Old May 18, 2006 | 07:21 PM
Greeny's Avatar
¯\(°_o)/¯
Jack it up and wiggle the wheel...A bad bearing will have good bit of play in the wheel...
Old May 19, 2006 | 02:34 PM
VEvolution's Avatar
I miss my VE
When my bearing went bad, I heard a constant "woosh woosh woosh" coming from that wheel when going above 40 mph.
Old May 19, 2006 | 02:54 PM
JET_MMPro's Avatar
I’d definitely check the wheel bearing. Do the wheel wobble test. If it wobbles, then your dealing with a bad wheel bearing. If the sound you are hearing is more of a “click-click-click-click” even if it’s a muffled click then you’re dealing with replacing the half-shaft (aka axle).
Or it could be the gusset bushing of the transverse link, might be torn or missing a portion with just enough gone to be noticeable during the momentum transitions. This is not a high probability, but as long as you’re under the car, take a look.
---JET_MMPro
Old May 19, 2006 | 04:15 PM
goon9's Avatar
Well no wheel wobble... I'm scared I might of over tightened the axle nut and damaged the bearing. Definetly a 'woosh' sound. I'll change the bearing and hope that fixes it.
Old May 19, 2006 | 04:24 PM
Greeny's Avatar
¯\(°_o)/¯
good luck mang..
Old May 19, 2006 | 05:02 PM
goon9's Avatar
Which is the better part?
http://oem.overnightautoparts.com/pa...aring&dp=false
I noticed the cheaper one is packable. Where as I know OEM is not.
Old May 19, 2006 | 09:36 PM
VEvolution's Avatar
I miss my VE
Well how much did ya torque it to? If I remember correctly, the FSM wants from 174 to like 224 or something.. My torque wrench barely went to 150 I would go with 200 if I could.
Old May 20, 2006 | 07:11 PM
internetautomar's Avatar
mod or sell?
I can get the NSK (OEM) for less than that price shipped if you want
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
