Maxima Rims
Old Jun 7, 2006 | 03:52 AM
unkn0wn180's Avatar
Maxima Rims
Hey Peoples
just wondering the specs on the maxima rims.
and if somehting of this size would fit and work nicely.
(not car is slightly lower than stock with harder suspention setup)
Rims are 17inches 2 are 8 wide, 2 are 9 wide, not sure of offset.
(have no tyres currently)
Old Jun 7, 2006 | 04:00 AM
Scope's Avatar
Im izz sexay
Stock maxima rims are 15x6 IIRC. The front rims you have may fit without rubbing but the rears you are gonna need some type of spacer. They may be a little too wide. Check the stickies above, I am not sure it the tire calculator is in it or not but check them.
Old Jun 7, 2006 | 04:14 AM
unkn0wn180's Avatar
What stickers?
Old Jun 7, 2006 | 04:16 AM
tripleGmax's Avatar
spacers will most likely do you no good. a 9 inch wide rim i think is gonna be hard pressed to fit under that wheel well. not to mention staggered on a fwd car is teh ghey!
Old Jun 7, 2006 | 12:10 PM
goon9's Avatar
Could trim the fenders and camber them right.
But I agree... Staggered wheels..... only if their g35's.
Old Jun 7, 2006 | 12:33 PM
pitchedup's Avatar
how so?
If your just cruising and not hitting the track, theres nothing wrong with running a staggered setup.
sublunary's Avatar
Originally Posted by unkn0wn180
What stickers?
stickies are the permanent threads at the top of the forum with lots of useful info
Old Jun 7, 2006 | 12:35 PM
tripleGmax's Avatar
Originally Posted by pitchedup
how so?
maximas already understeer pretty good. add a staggered setup (which you cant rotate) then have fun with more understeer. i dont care if you do it...i wont though.
Old Jun 7, 2006 | 12:55 PM
Frakk2000's Avatar
I bought 4x 18" 8" wide rims, will this fit? >_< yikes. And can I run 225/45/R18 on stock shocks/springs?
Old Jun 7, 2006 | 01:03 PM
pitchedup's Avatar
whats the offset?
Old Jun 7, 2006 | 01:04 PM
tripleGmax's Avatar
what offset. tire size should work
check wheel/tire section for more info
Old Jun 7, 2006 | 04:11 PM
Maxpwer's Avatar
No turbo, no care!
Actualy its not uncommon for FWD cars to run a stagered setup, but you have to put the larger tires up front. This helps reduce understeer!
Old Jun 7, 2006 | 07:14 PM
goon9's Avatar
WTF gives you that impression? A wider foot print drastically causes more understear.
And if you put them in the rear in fwd car... That creates not alot of drag, but more.
Old Jun 7, 2006 | 07:31 PM
tripleGmax's Avatar
common? maybe 1% of fwderz roll with wider rims up front....
Old Jun 7, 2006 | 08:33 PM
Maxpwer's Avatar
No turbo, no care!
uhhh, I hope youre trying to be funny? Pick up a Sport Compact Car magazine, they have a few of their own FWD cars that run staggered setup for the purpose of reducing understeer. If you have larger tires up front, and skinnier ones in the back, which one is going to reach the limit of adheasion first?
Agreed, which is why I wouldnt call it common, but instead I said "its not uncommon"
Old Jun 7, 2006 | 10:40 PM
pitchedup's Avatar
got to pick up a sport compact car magazine, did not know a staggered setup is used to reduce understeer for a front wheel drive car. Thought it will increase the understeer a bit.
Old Jun 8, 2006 | 04:34 PM
goon9's Avatar
...we don't drive sport compacts.
Old Jun 9, 2006 | 07:22 PM
colinod's Avatar
Are all the 3rd gen FWD? I need help too with getting dirt that gets spun onto the little holes on the stock (non hubcapped/ do you call them alloys?) When I wash it I attack it with a sponge everytime...still won't get off. Help?
Old Jun 10, 2006 | 02:33 PM
Frakk2000's Avatar
Hi, it was 40 or 30 not sure, but it was 5 off the original offset.
I had a local tire place to stick em on, and check if they would fit. They reassured me that even 19" with low profile (35) would fit a maxima easily, with original suspension.
Ive been driving around with my 18 inch for a couple of days, and everything seems fine. (I might be rubbing a tiny bit when I do a full swing to the left, I suspect my almost broken suspension.)
Anyways, getting new shocks and springs later this month. Also gonna post some pictures of my car, just gotta rid it of some rust
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
criminalslang810
Aug 16, 2015 08:12 AM
RealityCheck
Aug 5, 2015 06:18 AM
