please help me save time
Old Jun 7, 2006 | 06:37 PM
Jeff583's Avatar
ok guys i have been having this prob for awhile and seems to be getting worse so time to get it fixed, but im not sure what the prob is. It all started about 6 months ago while sitting at an idle my car all of the sudden started to miss just a bit, and not a constant miss either just every so often. Also it does it while driving but not during heavy acceleration, it pulls great when i accelerate just at low rpms is when this happens. There is no repatition to the miss just whenever it wants. Once in awhle it wont do it at all and other times it will be almost constant.
Any ideas, i would like to pin point the prob before i start digging in
Old Jun 7, 2006 | 06:51 PM
internetautomar's Avatar
mod or sell?
injectors
Greeny's Avatar
¯\(°_o)/¯
First thing to do is check/clean all the electrical connectors to sensors/injectors/etc.....
Intermittent problems are commonly due to a poor connection to a sensor or other electrical device..
Old Jun 7, 2006 | 07:18 PM
Jeff583's Avatar
should i use carb cleaner, isopropal alcahol, dielectical grease, ???? what is best and will not harm anything, when i cleaned injector connectors on my 89 i used carb cleaner but not sure if that will cause oxidation or not what do you guys think is best
Old Jun 7, 2006 | 07:19 PM
Jeff583's Avatar
injectors
if it was an injector(s) wouldnt it be a constant miss?
Old Jun 7, 2006 | 07:37 PM
mod or sell?
not neccesarily I had what I'm assuming was one fail intermittently, it ended up fixing itself so i never could confirm it's demise
Old Jun 7, 2006 | 07:43 PM
Jeff583's Avatar
somtimes i think mine has fixed itself, but then a few days later the dreaded miss will come back.
i hope it fixes itself, i have not had to rip into the motor on my 92 yet but once i hit 250xxx im doin a complete rebuild (currently at 223xxx) so not too far off, my 89 made it to 275xxx before had to put head gaskets in and that is still being drove daily so i hope the 92 will make it but im am starting to doubt it
Old Jun 7, 2006 | 09:45 PM
Cliff Clavin's Avatar
Way out West
I would be looking at your coil packs. This is what mine did when I had some cracks in one of the front coil packs. Check them over really good for cracks.
Later on, mine would have the stalling/bucking problem that turned out to be one of the rear coil packs.
Old Jun 8, 2006 | 03:42 AM
sublunary's Avatar
also run some seafoam or techron fuel system cleaner through. i thought i had bad injectors but the resistance checked out. problem went away with the injector cleaner
Old Jun 8, 2006 | 05:36 AM
Jeff583's Avatar
thought it was bad to run injector cleaner in our maximas???
Old Jun 8, 2006 | 05:48 AM
Greeny's Avatar
¯\(°_o)/¯
Nissan does not recommend running f/i cleaner in their injectors because the chemicals in most cleaners are too harsh...the ill effect of cleaners is cumulative,in other words one treatment in a attempt to unstick a injector is not going to destroy your f/i system/injectors...But periodic use over time can damage the injectors...
You can sometimes "unstick" a gummed up injector with f/i cleaner and get it back in operation again...It's a shot in the dark though...
Old Jun 8, 2006 | 02:53 PM
sublunary's Avatar
yeah i wouldn't run cleaner through all the time like the instructions on the bottles say, they want to sell more of thier product
Old Jun 8, 2006 | 03:07 PM
MrSector9's Avatar
my guess would be the coil packs also.
Old Jun 8, 2006 | 04:53 PM
Jeff583's Avatar
well i checked all my coil packs and non were cracked, most looked like they have gotten pretty hot but no cracks.
now what do you guys think
Old Jun 8, 2006 | 06:04 PM
Greeny's Avatar
¯\(°_o)/¯
One or two of them may still be bad even if they have no cracks...I help a local org member out a few weeks ago with his missing problem,none of his coil packs had any cracks...We swapped mine out of my car,the miss was gone...
If you were closer i would swing by and help you out...
Old Jun 8, 2006 | 08:29 PM
Jeff583's Avatar
is there any way to test them with a multimeter
Old Jun 8, 2006 | 08:39 PM
Way out West
You can, but testing them doesn't always help. They have a tendency to test OK, but fail under load.
According to the FSM, they should test out at .8 ohms and show 12 volts.
pkfinn
Jan 3, 2016 02:55 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
robtroxel
Sep 1, 2015 08:12 AM
delerium75
Aug 19, 2015 11:08 AM
