Help! Oil Light only on U turn.
Old Jul 2, 2006 | 05:44 PM
JRS89MAX's Avatar
Horrible day. While driving TEMP. needle shoots up to HOT. Let it cool down. Drive a couple blocks shoots up again. Saw the antifreeze reserve filling up but not getting sucked back up. Only when i let the car cool off. Drove like this for an hour and a half filling the radiator once till i got home. Changed thermostat and 50/50 antifreeze (good hour).Car sounds good. No knocking or nothing.Just belts squeaking from the antifreeze.Drove the car and left it on for a good 1/2 hour.Doesnt heat up. Nothing. Quiet like it was.
But noticed while i make a U turn the OIL light comes on and back off when i finished making the U turn. What the hell happen?
Old Jul 2, 2006 | 05:57 PM
disgruntled's Avatar
did you check your oil level? I know my oil light comes on briefly upon start up this one time when the oil level was much lower than it should be.
Old Jul 2, 2006 | 06:02 PM
JRS89MAX's Avatar
I checked the oil level its good. But im gonna change it tomm. Due to the engine being so hot for so long maybe burned it up. Looks a lil darker then i when i last checked it a couple of days ago.
Old Jul 2, 2006 | 06:20 PM
Greeny's Avatar
¯\(°_o)/¯
It's probably a faulty oil pressure switch..
Old Jul 2, 2006 | 07:06 PM
JRS89MAX's Avatar
Gonna look into that GreenMax.This pic is not of a VG? But the switch should be around the same location?
Old Jul 2, 2006 | 07:14 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah, probably not the right pic,but the switch is usually in the general area of the oil filter,not sure though...
Old Jul 2, 2006 | 07:19 PM
JRS89MAX's Avatar
Just found it on my Chiltons.Chapter 4 fig.12 LoL
Old Jul 2, 2006 | 07:24 PM
VEvolution's Avatar
I miss my VE
Anybody know what happens when this switch goes bad other then the warning light flashing?
Old Jul 2, 2006 | 07:35 PM
Greeny's Avatar
¯\(°_o)/¯
Would you translate that in english please..
Old Jul 2, 2006 | 07:42 PM
VEvolution's Avatar
I miss my VE
The damn oil pressure switch that is probably at fault according to you! What happens when it comes on?
Old Jul 2, 2006 | 07:45 PM
Greeny's Avatar
¯\(°_o)/¯
The damn oil pressure switch that is probably at fault according to you! What happens when it comes on? No oil pressure?
j/k
It is not going to mess up the engine if that is what your getting at...
It is just a simple switch..
Old Jul 2, 2006 | 07:47 PM
VEvolution's Avatar
I miss my VE
j/k
Oh okay, gotcha.. I wonder what activates it
Old Jul 2, 2006 | 08:03 PM
Greeny's Avatar
¯\(°_o)/¯
The switch activates the light when it senses no oil in it's proximity
Old Jul 2, 2006 | 08:11 PM
VEvolution's Avatar
I miss my VE
Ohhh, I get it now.. I gotta lay off the "green"
Old Jul 2, 2006 | 08:14 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 3, 2006 | 03:34 PM
JRS89MAX's Avatar
Changed the oil today ,OIL light doesnt turn on no more.Really did a job on my motor that stuck thermostat.Burnt my oil.I think 1 more mile and i would've blown the motor.
My thermostat that i took out says NISSAN on it plus it says 89 on the side.
Could that be original? Like for 18 years? How often must you change your thermostat?
Old Jul 3, 2006 | 05:40 PM
internetautomar's Avatar
mod or sell?
you're SUPPOSED to replace it every couple of years.
most people don't until it either causes the car to overheat or causes a lack of heat
Old Jul 3, 2006 | 06:23 PM
JRS89MAX's Avatar
I have my MAX for over 2 years put over 30,000 miles. Dont know what the previous owner had done to it. I beleive i should of changed it from the getgo. I learn as i go.
Old Jul 3, 2006 | 09:24 PM
ColombianMax's Avatar
You know, I used to have that same problem on my old Honda but it was when I tried going fast on round-a-bouts...kinda like Vans' style (lol)
Good to hear you got that problem taken care of
Old Jul 7, 2006 | 08:58 AM
Black92GXE's Avatar
Boomer Sooner
If you live in a semi warm to warm climate, just take the thermostat out and you'll not have to worry bout changing it Just hope it never gets cold out!
Hope all is well with the car!
Old Jul 7, 2006 | 09:29 AM
Greeny's Avatar
¯\(°_o)/¯
The problem with that practice is your ecu will stay in open loop[cold cycle] too long...This will add up to decreased fuel mileage and possibly engine damage over long term...
Old Jul 8, 2006 | 04:58 PM
JRS89MAX's Avatar
I was gonna leave the thermostat out too. But need my heat in these New York winters.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
