Starter and maybe tranny problems???
Old Jul 10, 2006 | 07:17 PM
traxtar944's Avatar
Would be lost w/out the org
Well my car crapped out today, perfect timing too. I'm in the middle of an entire overhaul of the car, and today it doesn't start. Here's the situation...I was doing a 3 point turn today because I came up to a dead end. When I put it in reverse, it jerked really hard. I was rolling forward very slowly still, but definetally not enough to cause a jerk this bad. Then, when I put it back in drive it started acting really strangley. I could put the pedal to the floor, but it would only rev really really slowly and only got to about 3000 before I let off. It almost felt like a manual does when you take off from second gear or something. No low end torque, and definetally no quick acceleration like normally. Well this was bothering me so I pulled into a parking spot and turned the car off. Now it doesn't even crank up again. I used a voltmeter and took off the relay for the starter and found that it get's 15 volts when the key is turned to the start position. I also found that the connector that should stay on when the key is in the run position stays at only 2.5 volts. I used a jumper battery pack and sent power to the switch wire for the solenoid and it turns the engine over, but it doesn't stay running, even with the key in the run position. The switch wire is white with a red stripe. I'm out of ideas about what this could be. EXPECIALLY with the rev problem. I had someone put their head down by the relay to see if they could hear it click when I turned the key, and it didn't click. I think the relay could be bad, or a ground to the relay could be bad. I really don't know! HELP!!!!
Old Jul 10, 2006 | 07:30 PM
Michael's Avatar
Back in a 3rd Gen.
well the first thing I would do is just check all the fuses.
Old Jul 10, 2006 | 07:36 PM
traxtar944's Avatar
thats the first thing i did, both under the dash inside and the relays like I was saying. Everything LOOKS okay
Old Jul 10, 2006 | 07:47 PM
vansskaterfreek's Avatar
may be a stupid question, but are all of your wires on top of the tranny still plugged in??? i think there are like 4 of them.....
ther eis a diagnostic test you can do on a tranny... i think it is on craig brace's page
Old Jul 11, 2006 | 08:14 AM
92 Max's Avatar
The relays on my car are about all the same. There's green ones (all alike) and there's blue ones (all alike). Try finding the same color relay somewhere else (say the accessory one under the dash) and switch it out with the bad one and see if it cures the problem. If it does, get a new relay.
Old Jul 11, 2006 | 04:14 PM
traxtar944's Avatar
HA!!! found the problem. It was a simple ignition fuse. I can't believe it caused so many problems. Sorry Michael I know you told me to do that and like I said it was the first thing I did, but it must have slipped past me on the first check. What pretty much happened was I ran out of ideas and started over, hoping I would catch something and I did.
Old Jul 11, 2006 | 04:27 PM
Michael's Avatar
Back in a 3rd Gen.
figured as much since I had the same thing happen to me. I washed my car and water got in the alternator. It blew a fuse and I was able to limp home in safe mode (the thing you had where it felt like the trans was slipping bad). After I turned it off it would not crank again. I think mine was the eng. cont. fuse or something.
Old Jul 11, 2006 | 06:16 PM
cparker5's Avatar
Do you know which fuse is for the radio? Can't seem to find any info on what fuse is what.
Old Jul 11, 2006 | 06:45 PM
Michael's Avatar
Back in a 3rd Gen.
do you have the fuse box cover? That is what you need to find out what fuse is what.
If you havent found it by tomorrow I will look at mine but I am going to bed this second and dont feel like going out side.
Old Jul 11, 2006 | 06:59 PM
traxtar944's Avatar
Yeah I was checking EVERYTHING too, even the fuel cutoff sensors in the trunk by the drivers side tail light. I'll try to get a diagram of the fuses so I can show you which one is specifically for the radio.
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
jwright36
Sep 8, 2015 11:45 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
