Factory alarm
Old Jul 16, 2006 | 09:35 AM
anaximander's Avatar
Factory alarm
I just disconnected the factory alarm by unplugging the switch below the steering wheel. I also disconnected a switch that runs to a small white plastic box right behind the metal anti-theft box because it's running through the same set of wires as the metal box. Anyone know what the white plastic box is and if I'm not supposed to disconnect that one? The car does start and there's no warning lights on.
Old Jul 17, 2006 | 12:23 PM
theophile's Avatar
I'm also interested in the answer to this one. My factory alarm goes off at random times when the door is opened with the key, even though it's not suposed to.
Old Jul 17, 2006 | 12:27 PM
Greeny's Avatar
¯\(°_o)/¯
I am not sure what the "white box" purpose is...but as long as there is no problems with the car..let it ride..
Old Jul 17, 2006 | 06:12 PM
Well today there was a problem. Battery warning light coming on, dash lights went out and clock being very dimmed. Is this somehow related to disconnecting the white box behind the metal anti-theft unit?
Old Jul 17, 2006 | 06:19 PM
Greeny's Avatar
¯\(°_o)/¯
Plug it back in and report back....
Old Jul 17, 2006 | 06:32 PM
The symptoms seem to be typical of a bad alternator. It just seems too coincidental thet it happened when I unplugged that white box.
Old Jul 17, 2006 | 06:43 PM
mszilves's Avatar
It's the Time Control Unit. As you can see from the table below, you probably want to leave it plugged in.
Old Jul 18, 2006 | 01:56 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 18, 2006 | 07:23 PM
Thank you gentlemen. Honestly I'd left it unplugged if it wasn't leaving the interior pitch dark at night. It gets rid of the annoying seatbelt and ignition key warning sounds.
Old Jul 25, 2006 | 09:04 AM
colinnwn's Avatar
Kill the door open/key in chime
From my site. Originally from Craig Brace I think...
I hate this supposed feature of many cars. The following mod will still give you the door open/headlights on chime so you don't run your battery down.
First, locate the time control unit under the driver's dashpad. Find the yellow wire with the blue stripe and cut it. You want to cut it where you have enough room to reattach it if you accidentally cut the wrong one or change your mind later. Thats all there is to it. No more of that incessant chiming when you jump out of the car and leave the keys in the ignition.
The seatbelt chime might be easy to kill also. I'd have to look around in the FSM to see if I can figure out how to do it.
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
