Car A/C smell
Old Aug 6, 2006 | 04:59 AM
u dun 4's Avatar
Car A/C smell
I was driving the other day. As we were hot I cut the A/C on. I smelling like a fish smell. Then I let it run longer with the windows down to help the smell completely get out the car. It didn't. Now I am just asking where does the smell come from and how can I get it away.
Old Aug 6, 2006 | 05:11 AM
u dun 4's Avatar
bump
Old Aug 6, 2006 | 05:31 AM
Greeny's Avatar
¯\(°_o)/¯
Spray some lysol in the vents....
Old Aug 6, 2006 | 10:09 AM
internetautomar's Avatar
mod or sell?
you have mold on your evap.
if you really want to get rid of the smell be prepared to tear ou the dash.
also sheck the drain hose, it may be plugged as well.
Old Aug 6, 2006 | 10:56 AM
KeithD's Avatar
Anti-bacterial lysol is the easiest way of band-aiding stinky AC.
Old Aug 7, 2006 | 07:49 PM
xx-Marshall-xx's Avatar
kthxbye2u
its a dead lizard i guarentee you lol happened to me it was unBAREABLE! lol
then one day i was cleaning my car and hopefully get the smell out while cleaning and ran them on full blast... and a dead lizard lol i was like "OH DUDE!" ahahha just gotta wait till it gets rotten enough to get blown out AHAHAH
Old Aug 7, 2006 | 08:40 PM
u dun 4's Avatar
I just spray the Lysol into the vents while its not on and it will take the bad smell out. Lysol, Fabreeze, or something like that. I cant stand the smell and when a girl got into my car i couldnt even keep the A/C on. So I need a easy remedy.
Old Aug 8, 2006 | 03:45 AM
nelledge's Avatar
"I'm just sayin'..."
This method worked for me for a few weeks. Buy some Ozium at teh local parts store. Park you car. Let it idle with the heat on full blast. Yes, the heat. Spray it liberally in the fresh air intake by the hood and windshield. Keep windows closed and allow heater to run for a good 5-10 minutes.
Important Safety Note: Ventilate the car before getting back in for any period of time.
Good luck.
Old Aug 8, 2006 | 06:51 PM
u dun 4's Avatar
I will definately try that out. Thank you .
Old Aug 8, 2006 | 07:40 PM
nelledge's Avatar
LMK how it works for you. I'm curious if it will help the fish smell. Hopefully it's not a coolant leak.
Old Aug 8, 2006 | 08:24 PM
u dun 4's Avatar
What would I be able to do to tell that and if it is then whats the problem with that?
Old Aug 19, 2006 | 09:08 AM
92 Max's Avatar
I had the same problem. It's better now, but not gone. You can remove the glove box, and behind it is an oval metal plate on the heater ducts behind it with two screws. This is the blower resistor unit. Carefully remove it (don't break the resistor coils behind) and you can access the a/c coils behind it. The hole is small, but with some creativity ( shop vac with small attachments, small light on a stalk) you can clean out the a/c area that's filled with pine needles, leaves, dead rodents, etc. that will help the smell. You can then buy some a/c cleaner or spray the a/c coils inside with an a/c cleaner you can get from NAPA or make a deoderant from a 1% solution of bleach (don't get on fabric). I made a cleaner like this, put a plastic sheet over floor and glove box opening and sprayed the coils, let it sit. Don't over fill the coil or it will leak on the carpet. This helped a lot.
Old Aug 20, 2006 | 12:19 AM
Duckman540i's Avatar
VE Powah!!!
Ya, my dad's Nissan truck had the EXACT (Fish) smell with the AC on, or even just vents on with no AC. It happened to be some rotten leaves stuck in the Blower. Maybe that is where the problem lies. Also, don't fear taking the glove box apart, its trivial, and pretty much self explanitory. Good Luck!
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
