Teh 300k club: sign in..:-)
Old Aug 17, 2006 | 09:28 AM
  #41
Alex_V
Originally Posted by VEvolution
Nice wrkllc... Where did you get that cluster from? I don't think I've seen that one yet
Are you kidding? Thats the 89-94 GXE cluster. It stock.
~Alex
Old Aug 17, 2006 | 09:52 AM
  #42
VEvolution's Avatar
I miss my VE
~Alex
Nope.. Take a look at that temp gauge. That gauge was definatly not the one I had on my 93'GXE. The SE I have now has this design in the pic just white faced.. And also the text looks waayy different. I could have swore I seen that cluster in the Stanza or something..
Edit: Also look at the RPM digits.. Much bigger then I remember them being.
Old Aug 17, 2006 | 09:57 AM
  #43
Alex_V
Ive seen plenty of GXE's 89-94 at the local picknpul that look like that.
~Alex
Old Aug 17, 2006 | 10:06 AM
  #44
Michael's Avatar
Back in a 3rd Gen.
to clear things up the 89-91 GXE cluster does have a different font on the numbers and such than the 92-94 GXE so it does indeed look different.
His is stock for an 89-91 though.
Old Aug 17, 2006 | 10:10 AM
  #45
VEvolution's Avatar
I miss my VE
I figured but didn't wanna get way ahead of myself Thanks for clearing things up.
Old Aug 17, 2006 | 11:08 AM
  #46
wrkllc's Avatar
Well, I put another 89 miles on today 8/17/2006 Should we start a 400,000+ Club?
When this car dies, I will leave a note inside "If found dead on the side of the road, You may keep it" lol.
Old Aug 17, 2006 | 11:23 AM
  #47
MaximamixaM's Avatar
wrkllc, that is impressive...400K miles. Have you done 60K timing belt changes-that would be around 6 of them? How about shocks/struts or other repairs?
How did your alternator last nearly 400K miles-mine died at around 110K miles?
Old Aug 17, 2006 | 12:06 PM
  #48
Pearl93VE's Avatar
I can has?
Just Hit 130,000, 3rd transmission (second one was rebuilt, this one is new) Just replaced Alternator a thousand miles ago. Engine still pulls strong though!
________
Bong vaporizer
________
EXTREME Q VAPORIZER
Old Aug 18, 2006 | 08:22 AM
  #49
wrkllc's Avatar
Yes I did the timing belt every 70k miles next one due at 420000, I did just replaced the shocks/struts about 390k this is third set, When I do the timing belt I change ALL the belts and hoses as well as the fuel hoses, on the motor.
At the time I had to do the transmission I also changed all the Motor mounts (they were shot), At about 315K changed out the control arms and bushings, and the steering rack as is was about to let loose. 3 or 4 drive axles CV boots etc...
As for the Alternator I have no idea why it lasted so long but in the same week when it died my other 1992 Maxima with 134K miles its alternator died. The starter is original, (knocking on wood) The motor has Only had the Head gaskets replaced as I blew one while driving over the bridge in Tampa Bay. which resulted in a new radiator, I took it to the local Nissan Dealership as I did not have time to look at it, they called the next day and told me to come over and look at the motor, when I got there four service techs were looking over my car, and the service manager asked me at what mileage was the motor replaced, I told him it was the original motor and it had never been touched except for routine maintenace, He said look at the cross hatching it still looks brand new whith no ridge. (I have pictures somehere) I told him I change the oil every 3000-4000 miles, and drive it everyday. They could not believe it. Then they wanted to do a complete head job because of the mileage, I said no do not touch the heads, when you redo the heads you will have to redo the bottom end as well. So I still drive it every day, it does leak oil out of the front oil seal as the the crank shaft has a seal groove worn into it. But just a small amount, so I keep an eye on the oil.
Sorry for rambling on but thats the scoop on it.
Old Aug 18, 2006 | 08:34 AM
  #50
wrkllc's Avatar
Heres some pictures of the head gasket and cylinder wall
Old Aug 18, 2006 | 08:41 AM
  #51
Maxmus_X's Avatar
SHIFT_PANTS
[QUOTE=wrkllc]Heres some pictures of the head gasket and cylinder walls
and this is the same 400k motor?
Old Aug 18, 2006 | 08:49 AM
  #52
wrkllc's Avatar
Yes! I took these pictures when the service department called me to come over.
Old Aug 18, 2006 | 09:49 AM
  #53
jaguax's Avatar
That is impressive. Dude, you should totally go for 500k.
Old Aug 18, 2006 | 10:40 AM
  #54
VEvolution's Avatar
I miss my VE
Yeah, I think you can be the first
Old Aug 18, 2006 | 12:33 PM
  #55
Maxmus_X's Avatar
SHIFT_PANTS
You might, small chance, get a new car from nissan for going 500k. I remember somewhere a honda accord guy drove for 500k and got a new car from Honda. So who knows, just keep it up!
Old Aug 18, 2006 | 12:51 PM
  #56
Greeny's Avatar
¯\(°_o)/¯
Who would want one their new ones..
Old Aug 18, 2006 | 01:38 PM
  #57
internetautomar's Avatar
mod or sell?
would you really want an old one?
Old Aug 18, 2006 | 01:42 PM
  #58
Maxmus_X's Avatar
SHIFT_PANTS
I would agree with both of you on that. Maybe next gen...
Old Aug 18, 2006 | 02:56 PM
  #59
wrkllc's Avatar
I will give it a try at 500k,
What happened to the pictures I posted?
Old Aug 18, 2006 | 03:03 PM
  #60
Michael's Avatar
Back in a 3rd Gen.
cardomain is down I believe. I tried to go to my cardomain site a little while ago and it was down.
edit...I see you didnt use cardomain so I dont know.
  #61
jaguax's Avatar
Just curious, how well does it run? Does it start up right away? And more importantly, does it still pull the car? heh
Old Aug 18, 2006 | 07:02 PM
  #62
wrkllc's Avatar
Starts right up, still has the pep, but not as good as my 94, The A/C with original compressor still gets cold I keep it on 2 or 3 as stated before everything works, but the clock will come on/off but they are known for that, if I wiggle the conector it works for awhile. I still get between 300 - 365 miles to one tank of gas. When I travel accross the State I cruse at 70-80 no problems. But hey with these miles I count every one now. I will drive this car until it dies. I keep the tires and fluids up as well as alignment and such. It actually rides better than the newer ones. But I keep over 150lbs of tools in the trunk for my job. The last hurricane season did a toll on the paint as roofing shingles scraped accross the roof and windshield, and the paint has worn off the top off the mirrors, clear coat is long gone.
Old Aug 18, 2006 | 07:05 PM
  #63
wrkllc's Avatar
Just relisting this picture to see why the others are missing. Using www.upshizzle.com ????? don't know why lets see if it still works.
Old Aug 18, 2006 | 07:25 PM
  #64
wrkllc's Avatar
cylinder cross hatching
Old Aug 18, 2006 | 07:36 PM
  #65
VEvolution's Avatar
I miss my VE
Your not scared shes gonna leave you stranded being that old? I hope you have a back up plan incase that happens
Old Aug 18, 2006 | 07:43 PM
  #66
wrkllc's Avatar
Well I hear you, when the head gasket blew I was on the Gandy Bridge in Tampa Bay, I live in the Orlando area, so Yes I had it happen already, the tow truck driver dropped me off a the Tampa Airport Rental car area and I just rented another and told him to tow it Universal Nissan in south Orlando. Insurance paid $75.00 I had to pay $50.00 Remember I have a spare 1994 maxima at home anyway. But Yes I am waiting for it to happen. Have been for the last 10 years, LOL
The Guys at Nissan in Tenn. said "next milestone 500K.keep it going"
Old Aug 18, 2006 | 08:03 PM
  #67
wrkllc's Avatar
I am not going to hold my breath.
Cotozic
Jun 28, 2017 08:01 PM
sdotcarter
Sep 2, 2015 09:53 PM
Viralkill
Aug 15, 2015 11:52 PM
