Auto tranny not shifting.
Old Aug 28, 2006 | 05:12 AM
nicks79's Avatar
Hey everyone. I picked up an old 93 max this weeekend. it was free from a friend. The only problem it has is that when you shift in any position, D, R N, it doesn't engage in any gear. Its not a cable cause I jacked it up and linkage is OK. I suspect its something inside.
His doughter was driving it, so she probably shifted while rolling, or something...
Anyways, I've taken apart few manual trannys but don't know much about autos.
Does anyone have any ideas what it could be. I plan on dropping it this week and see whats going on.
Old Aug 28, 2006 | 05:16 AM
Greeny's Avatar
¯\(°_o)/¯
My guess,broken input shaft...
Buy micheals tranny..
Old Aug 28, 2006 | 05:41 AM
internetautomar's Avatar
mod or sell?
chances are the planetary is trashed or an input shaft.
no matter what it will be a "hard part" which means $$ it'll be cheaper to get a used tranny than rebuild your current one.
Old Aug 28, 2006 | 07:58 AM
nicks79's Avatar
Thanks for the responses.
What I also noticed is that when switching between positions, RPMs jump up and down as if it was engaging, just like on the working car.
What I also noticed is when on jacks, I pu it in D, the front wheels started to rotate slightly, then stopped.
Park is working, no prob.
Also, used tranny is about $500-700, and the part should be less. Isn't better to put in a new part.. Though car has 186k miles on it, probably originaly tranny.
Thanks.
Old Aug 28, 2006 | 08:14 AM
mod or sell?
the trans cost and availibility of parts is partially dependant on whether you have a DOHC or SOHC motor. the trannies do not interchange because of a starter issue
Old Aug 28, 2006 | 10:10 AM
Alex_V
Ill sell you my auto tranny for $150. Pulled out of the max cuz it didnt move and it was a stripped tourqe converter. shipping extra, pm me if your interested. It also has 186XXX miles too.Oh and mines for the SOHC or GXE model, wont fit the 93 SE/DOHC.
~Alex
Old Aug 28, 2006 | 10:22 AM
nicks79's Avatar
According to sticker I have VE30 DE, which I think is DOHC. thanks for the offer though. I think i preffer to get my hands dirty.. Anyone knows if the tranny is much heavier then manual one? cause i don't have a jack and manual isn't too heavy.
Old Aug 28, 2006 | 11:11 PM
Jon94SE's Avatar
Are you saying you only have one jack? I don't think it's possible to pull the tranny with out a jack is it
Old Aug 29, 2006 | 03:49 AM
nicks79's Avatar
well, the manual tranny on my 00 Max is no problem to pull out, just need some one to help unscrew few bolts while i hold from the bottom. I was just wondering if the automatic is much heavier..
Old Aug 30, 2006 | 06:20 AM
nicks79's Avatar
anymore comments on this?? Does this require to drop tranny down?
Old Aug 30, 2006 | 06:23 AM
Michael's Avatar
Back in a 3rd Gen.
yeah the auto transmission is much heaver than the manual. You will probably not be able to lift it up and put it on without a jack.
Old Aug 30, 2006 | 11:13 AM
Jon94SE's Avatar
alot of auto problems on here lately, looks like some people need to start investing in 5spds
Old Sep 11, 2006 | 06:09 AM
nicks79's Avatar
Here is what I found out this weekend. While on jacks, I put the shifter in any position and nothing happens. THen i give it a gas, the wheels rotate very little, maybe like 1 rev per second. So anyone has any ideas? Is it the valve body? Torque converter or oil pump. It doesn't feel like there is anything broken mechaniacally.
Old Sep 11, 2006 | 03:24 PM
shutdown77's Avatar
89 Maxima wouldn't shift into 3rd gear.
Gotta question if anyone can help. I was on the highway the other day and my 89 Maxima wouldn't shift into 3rd gear. I kept it at 55mph to be safe and the rpms went all the way up to 5. I then parked it for about 45 minutes and now it's fine? Any ideas. Thanks
P.S. It's an auto tranny with 140,000 ,miles.
Old Sep 11, 2006 | 05:50 PM
mod or sell?
solenoid sticking possibly
Old Sep 11, 2006 | 06:34 PM
shutdown77's Avatar
Is there any solution that I personally can do about it?
Old Sep 11, 2006 | 07:24 PM
mod or sell?
try some trans additive
Old Sep 11, 2006 | 07:36 PM
shutdown77's Avatar
What's the best one to use for an 89 max?
Old Sep 11, 2006 | 09:53 PM
maxitech's Avatar
I have an extra solenoid pack for sale...still in its original packaging. Let me know if you are interested.
Old Sep 11, 2006 | 10:20 PM
Gun5's Avatar
how much, and where are they located on these cars on my firebird they are in the tranny pan
Old Sep 11, 2006 | 11:46 PM
maximagician's Avatar
nicks 79...ive had a torque converter strip out where the input shaft goes in it .i got a new one for like 200 bucks and some seals and learned the hard way how to r and r a trans, the shop said its a common prob,this might be why the wheels barely spin only off ground, have someone shut the motor off while you listen around the bell housing.. i could hear my converter spinning in there a few revolutions, kinda scraping .when i pulled the trans i let the fluid outta the converter and looked in with a light .tilt it if the fluids in the way,mine was obviously chewed up
Old Sep 11, 2006 | 11:53 PM
[QUOTE=shutdown77] on the highway the other day and my 89 Maxima wouldn't shift into 3rd gear. I kept it at 55mph to be safe and the rpms went all the way up to 5. I then parked it for about 45 minutes and now it's fine? [/QUOTE
you sure it was in drive and not accidently 2..(shifter linkage right?)..was overdrive on?fluid clean and full?
search for the auto trans computer code check in this forum(if you donated)
Old Sep 12, 2006 | 07:40 AM
maxitech's Avatar
Not 100% on where they are located since I never installed it. It was $125 new, I'll sell it for, say, $60.
Old Sep 12, 2006 | 08:20 AM
nicks79's Avatar
THis is called Thread Stealing...
But thanks for other's replies
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
dshinn
Sep 26, 2015 08:07 PM
